No power Its 21v-l80m
What number power regulator of sharp tv.20v l80m
If you wish to get some details; check the site linked here. Pull up older posts.
May 22, 2016 | Sharp Televison & Video
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a ยท Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Dec 28, 2015 | Sharp Televison & Video
What is the number of the audio output of sharp 20V-L80M? the IC number is erased.. thanks
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagram is given.
Oct 12, 2014 | Televison & Video
Sharp tv 20V-L80M standby only
If not power up even by remote control then check the the H-out transistor for short, open fusible resistor in line with the b+. This is the most common fault of your problem.
Needs a technician to isolate the problem.
Thanks for using fixya.
Jan 23, 2011 | Sharp Televison & Video
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
Aug 10, 2009 | Numark DM1200 DJ Mixer
21v-l70m
sorry bat you heve need the asistence califications your problems,needs oscilografition/time
May 23, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
