Question about Gigabyte Technology gigabyte Ga-78lmt-USB3 Socket Am3/ Amd 760g/ Ddr3/ USB3.0/ A&Gbe/ Microatx Motherboard
Stop post screen showing on boot
I want to stop the post screen showing on boot
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Gigabyte Tec... Master
  • 2,226 Answers
It is in cmos you need to go there hit the delete key on startup ok
Posted on Mar 24, 2014
Mac book pro. Black screen cannot start but with boot sound
Have you tried connecting an external monitor.
A boot chime means the Mac has passed POST, that the screen remains black initially suggests there is a problem getting image to screen which could mean a bad cable to the LCD or the LCD display its self is having problems.
By connecting to an external display you verify the graphics on the logic board is functional, and it could get you up and running till the display problem is fixed.
Also try powering up and when you hear the chime, hold down the COMMAND+OPTION+P+R keys, and keep holding them till the machine has chimed 3 times, this will reset the 'BIOS' in case there is a glitch there stopping the display from showing up.
Apr 14, 2014 | Apple Computers & Internet
Compaq CQ50 wont load
YOU are to be COMMENDED!
Do you know how many do not even post the manufacturer name of the computer, much less the model number?
Plus adding the diagnostic measures you have posted?
Wish more people would use the problem area you have used, and wrote a PAGE! lol!
Do need the model number though, along with the model series number you posted. This way I can look at the BIOS versions.
(Example - CQ50-100CA)
Need to ask.........is CDROM the first boot device in Boot Options?
(BIOS Setup)
Could be of course, but you didn't post it. Makes a BIG difference.
The computer HAS to boot from the CDROM, then.
Post back in a Comment.
Regards,
joecoolvette
Mar 06, 2013 | Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
I turn my computer on, and no boot, no no sound, no nothing. I looking inside and I see a red light on the motherboard that I thought should be green. right under it is the label LED1.
When you see the red led that is telling you there is a motherboard problem . Really helpful isn't it?
There are only a few things that will stop it from shoing more life that that. One is a bad power supply or bad ram. Those will stop it from showing anything or doing anything. A bad cpu usually shows more of the boot sequences before it stops. If you were seeing any errors or any blue screens just before this happened then it is most likely the ram. Because it isn't showing any post codes or beeps then the problem will be in the #1 module. To do post tests the first 64k or ram or so needs to be good. If you have more than one ram module take them out and put the #2 into the #1 spot. If it works then it is your old #1 ram module.
You should also try reseating your ram and the cables and any connectors. While not common the odd time that will be the cause.
If you cannot see any change after swapping ram then you may have a more serious problem on the board itself. Probably 9 out of 10 times the cause is the ram.
Nov 13, 2010 | Syntax SV266M Motherboard
I have a hp Compaq 6735s...it refuses to start up...when it passes the post screen it does not show...but i tried booting from safe mode it boots normally...i then repair the OS thinking it was gonna stop...
can you access bios screen (hold f10 during startup)? if so go there and test memory modules (run in test) and this also will test hdd. can you see any blinking/lit leds? then give me more info.
Sep 25, 2009 | HP Compaq 6735s Notebook
VISTA boot stop and shows ACER recovery screen .
Restart PC
Press F8 as it restarts.
Select Safe mode and see if it workes.
Restart PC again.
Select "Last known good configuration"
If this does not work either,
Do a system restore.
Jul 19, 2009 | Acer Aspire 5315 Notebook
A7V400-MX will not boot
In such cases its practical to change the SMPS with a working power supply of the same rating and then trying it out. If with the new power supply it works fine then cange your SMPS. Also make sure that all cables are snug tight and generally ree from dust. The same applies to your RAM too................sodeep
Apr 18, 2009 | ASUS A7V400-MX Motherboard
While booting error " bios shadowed " & 0175: bad crc1, stop post task
sounds like cmos battery flat small battery inside pc to retain cmos setting when pc switched off
Oct 02, 2008 | IBM ThinkPad T20 2647 Notebook
Gigabyte Technology gigabyte Ga-78lmt-USB3 Socket Am3/ Amd 760g/ Ddr3/ USB3.0/ A&Gbe/ Microatx Motherboard Logo
85 people viewed this question
Top Gigabyte Technology Computers & Internet Experts
David Payne
David Payne
Are you a Gigabyte Technology Computer and Internet Expert? Answer questions, earn points and help others
