Question about Hotpoint Washing Machines
Water not going into machine wmf940
No water going into the machine
    Problem Solver:
  • 7 Answers
Id say its the inlet valve faulty. easy replacement.
Posted on Apr 11, 2014
Does anyone know Why the hot water does not go into the machine when using warm water selection, hot water is in hose but not in machine ?
The hot water valve is not opening. This could be the valve or the timer. What make and model and year is it?
Sep 12, 2014 | Washing Machines
My hot point aquarius wmf940 washing machine door won't lock
If this model has brushes check them first.
check wiring to door lock
new door lock
new board/motor.
This is the order i would go at trying to solve the problem
May 23, 2012 | Hotpoint Washing Machines
Hotpoint aquarius wmf940 filter cap wont come off, it appears jammed, is this normal and is there a solution?
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 18, 2011 | Hotpoint Washing Machines
Wmf940 wont switch on checked fuse checked wall socket still nothing machine only 4 days old
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 18, 2011 | Washing Machines
Hotpoint aquarius wmf940 wont spin or drain water out f05 fault how do i remedy this
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom ( behind the clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked. Ofter that, unscrew the round cap, remove the filter and clean.
If the filter is not there, you will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 10, 2011 | Hotpoint Washing Machines
Hotpoint WMF940 Washing machine - 11 months old. The cycle times displayed do not represent the actual times. No 5 cycle takes over 3 hours. The other displayed cycle times are similarly not...
If it is indeed less than a year old, then I recommomend you contact Hotpoint direct as the washer will still be under the years guarantee,and you should get a call free of charge
Check with Hotpoint at the web address below.
They should be able to help you.
WWW.HOTPOINTSERVICE.CO.UK
Jan 03, 2011 | Washing Machines
WMF940 Child lock will not deactivate?
unplug the machine completely and plug it back in. Wait a second & it should deactivate.
May 25, 2010 | Washing Machines
Ariston AVXD 129 washing machine displayed F--05
my washing machine displayed F--05 and water is not going out, I clean the pump and start the machine but the water is not going out. wHAT TO DO?
Jul 01, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
