Question about Canon PIXMA iP4600 Color InkJet Photo Printer
Canon PIXMA iP4600 - error 6A80
I just got a Canon PIXMA iP4600. I keep getting error code 6A80 when I try to align the printhead with the software. I checked all the ink tanks and i checked the printer head. I can't find anything wrong. When I turn on the printer, the power light and alarm light flash alternately. Please help!!
  • lilami Jun 14, 2009
    That is not the same problem I am having...the print head DOES return to its home position, and there is no spring jammed near the black sponge.
  • 221 Answers
Hello someone else here had this problem, this is what he posted: "Same problem with a Canon MP540 fresh from the box. Turned out to be the print head unit was not returning fully to the home position ie extreme right. My Fix : When the scanning unit cover is raised the print head unit moves left for access, look in the vacated area to the right, in particular the small black sponge where the head normally parks. I found a small spring jammed in beside the sponge, removed it and all is well. Don't know what the spring was meant to do but everything is working fine without it.On the MP540 the head unit now glows red, presumably meaning all is well... "
Posted on Jun 14, 2009
Canon PIXMA iP4600 error message string-USB002
issue with registry uninstall the driver remove the entries from registry . reboot the system try again
skype id :johnwalker800969
Sep 09, 2016 | Canon PIXMA iP4600 Color InkJet Photo...
How will i solve error B200.in canon ip4600
no way to solve it, you might cover pins to get printer working in fiction because it wont print at all, the only way is to change printhead
Jul 23, 2014 | Canon Pixma iP4600 InkJet Photo Printer
My Canon Pixma i4600 "ate" a sheet of paper. Although I was able to get all the pieces out again the printer does not move anymore. Instead, it shows support code 6a80. Can anyone help? Thank you.
The print head is locked
feed a piece of paper through the back and manually turn the white roller until the paper is 3/4 through. Turn the printer on and the printer should take the paper and run it the rest of the way through.
Sep 24, 2013 | Canon PIXMA iP4600 Color InkJet Photo...
My Canon PIXMA iP4600 keeps reporting a B200 error. Turning it on and off has not helped yet. What else can I try?
I am sorry to say that you will need a new printhead and main logic board to solve this error. What has probably happened is the printhead has shorted the logic board. So unfortunately you MUST replace both together. I think this may be rather expensive.
Sorry.
Jun 19, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
PLEASE HELP ME WITH ERROR 6A80[canon 4600]
first you proper installed software by original driver cd deliverd by cannon after if problem still continue then check cartridge but cartridge should be ok , specialy in cannon cartridge demo cartridge working for very short period replace new one originally cartridge, or if your printer sensor ribbon deeply scrached it should be replace.
Feb 19, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Service Error 6A80
That error says there is something jammed in either the purge assembly or the sheet feeder on the back not able to turn. The purge assembly is on the right where the printhead parks for cleaning.
Oct 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a Canon PIXMA MX860 and have error 6a80. i have shut off and on twice no paper jam. totally stuck
6A80 is a purge unit error, the purge unit is the cleaning assembly on the right where the printhead parks when shut down. If you can move the carriage out of the corner, use a flashlight and see if there are paper scraps or the like keeping the purge assembly from moving freely.
Oct 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Alignment of printhead on Canon Pixma iP4600
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Jan 03, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
4,306 people viewed this question
old marine
old marine
