Dell rev a01 motherboardCan a ATX power supply used in this motherboard ?
Dell mother board rev a01
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Computer shop have them or best buy
Posted on Mar 24, 2014
map9966
  • 2351 Answers
SOURCE: Jumper settings for an AMD 550 mhz K6-2 chip.
If you still have your manual, see page 19. Set CPU External bus frequency (100MHz) as shown & CPU to bus use 5.5x = 550MHz.
You can download the manual here:
http://www.fic.com.tw/support/download.aspx?dl=motherboard%2fmanual%2fsocket7%2fva-503%2b%2fva-503%2ba4sh.zip&title=va-503%2ba4sh.zip&info=manual
There seem to be more setting after going over the manual.
Any of these power supplies will work with the FIC board. All come with the 20-pin ATX main power. Some come with 24-pin power connector that you just do not use.
As far as finding a power switch for an ATX power supply try looking to a Good Will store. Most places have old PC parts for sale cheep. or try here: http://www.trianglecables.com/atxcaspusbut.html
http://www.directron.com/switchat.html
Good luck skivvynine!
Hope you find all this helpful.
Mike
Posted on Dec 18, 2008
SOURCE: motherboard
looking for the user manual for a matsonic ms8137c+
Posted on Jan 16, 2008
map9966
  • 2351 Answers
SOURCE: motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Posted on Jun 02, 2008
preachw996
  • 1179 Answers
SOURCE: CPU Fan on my Dell P4 goes full speed when I boot up
It is a thermal problem. Try replacing the CPU fan & make sure you use a good thermal grease when reinstalling. Hope this helps.
Posted on Jan 13, 2009
  • 3 Answers
SOURCE: can a 20 pin atx power supply cable be used on a
yes, you simply need to buy a 20-24 pin adaptor lead for about 3.99.
Posted on Apr 14, 2009
My smps is working, but my power is not coming to the mother board
Replace the power supply or have it tested.
Amazon com bestec atx 300 12z You can get a replacement pretty cheap. Most all power supplies can also be tested - Bestbuys geek squad or a small computer repair shop should have the means to test it.
Feb 23, 2013 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
There is any different between this mother board p/n 51884327 and p/n 51882625
Take the power supply to a retailer or computer shop in your local area. Pretty standard from what I have found out.
Bestec ATX 300 12Z Rev DDR Replacement Power Supply HP 5188 2625 Have a great day.
Jul 29, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Can not get computer to power back up no lights on front o rear just little light on mother board have dell 8400
Bad Power Supply, sscorbett.
Usually you have enough power to light LED lights, (Like the harddrive activity LED light for add-in cards, that you see on the motherboard), and spin fans, but Not enough power to turn the Processor on.
Dell Support >Dimension 8400 > Service Manual
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
Technical Overview > System Board Components
http://support.dell.com/support/edocs/systems/dim8400/SM/techov.htm#wp1052739
harddrive activity light for add-in cards (SCSI LED)
The Dimension 8400 comes with an ATX style of Power Supply, that has a maximum rated Wattage of 250 Watts.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Your Power Supply just has enough power to light that LED light.
Weak voltage power rail.
Replace the Power Supply.
[ There are three power rails inside that SMPS.
Switched-Mode Power Supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail ]
The ATX form factor for a Power Supply refers to the size, and shape of the case, for one.
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall.
The ATX power supply case in the Dimension 8400 however, is shorter in length.
It is 4 inches Long. (Depth)
Not an advertisement for the website, nor manufacturer.
Reference for the case size, and power cables needed,
http://www.cputopia.com/hp-400w-dell-dimension-8400.html
Scroll down to see the connectors of the various power cables needed.
You may have a Power Supply with these dimensions, and needed power cables, in an unused computer.
Perhaps someone has upgraded to a better computer, and has an unused computer that you can temporarily borrow the Power Supply for a test unit.
Make sure it has at least 250 Watts (Maximum rated wattage), plus,
1) 20-pin ATX main power cable. (Or a 20 + 4-pin ATX main power cable)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[ 20 + 4-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4 ]
2) 4-pin ATX +12 Volt power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Plus the various power cables needed for the Harddrive, optical drive/s, and computer case fan/s, if it/they do not connect to the motherboard.
Oct 21, 2010 | Dell Dimension 8400 power supply ** FREE...
Not powering on my mother board
1st You check the power supply of computer. If the power supply is alright then check the connector.
  • It is properly connected on the motherboard.
  • Check the motherboard LED light on.
Mar 13, 2010 | Intel Desktop Board D945PVS - Mainboard -...
Hello there, I got Asus PC-DL Deluxe UAYZ motherboard and would like to connect to ATX 300W 20 pin power supply. Do you think it works, or should i wait till i find 24pin power supply. thanks for your...
This motherboard is designed to be used as a workstation or server. This mother board will need a specific power supply designed for this board as it can use 2 Xeon CPUs. Setting this board with the incorrect power supply will cause the system to not power up or at worse result in damage to the CPU, motherboard, memory, video and other devices including possibly the power supply. I suggest obtaining the proper power supply for this motherboard
The manual for this board states that the motherboard requires a 24 pin ATX power supply that also has an 8 pin 12 volt connector. The manual from ASUS recommends no less then a 300 Watt power supply. I would professionally recommend 500 watts or more if the system will use 2 CPUs and many hard drives in a RAID array.
A suitable power supply can be found here at Newegg http://www.newegg.com/Product/Product.aspx?Item=N82E16817163111
The manual is here at ASUS's support site at http://support.asus.com/
Feb 24, 2010 | ASUS PC-DL Deluxe (90-MSV290-G0UAY)...
Del inspriron 8100... It was working but a bad fan.. opened it up (ok I know all the comments)... but now I dont even have power to the mother board..... last hope..
reseat the 120v cable for the processor and as well as the 40 pin ATX cable still if u dont see the light lit on the motherboard, u have to replace the motherboard. but before that remove the hard drive & optical drive , memory and the pci card and check once again, if no go, replace the motherboard
Oct 18, 2009 | Dell Dimension 4300 Power Supply- FREE...
POWER SUPPLY FOR E-MACHINE
disconnect CDROM,DVDROM or any player for that matter and of course any other peripheral attached so as you remain with only monitor ,mother-board,hard disk connected to the power supply.if it doesn't work repair the faulty supply.
Aug 10, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
