Question about Toshiba 32AV615DB 32-Inch Lcd Tv Dvb-t Freeview Hd Ready 1366x768
Two broad coloured lines across screen when I switch on. Sometimes they last for long time and problem getting worse
Broad coloured lines horizontal
latino
  • 93 Answers
SOURCE: Horizontal Lines Across Screen of Toshiba 24AF41
check for a bad capacitor in the horizantol section
Posted on Oct 29, 2007
Mike1963
  • 8 Answers
SOURCE: WHITE LINES
Replaced C407 100uf/35V Vertical section.
Posted on Mar 04, 2008
Joed911
  • 4338 Answers
SOURCE: Funny screen and refusal to start
Sounds like a Video ram or system ram problem which is on the system board. Needs service.
Posted on Sep 29, 2008
benwabnick
  • 2404 Answers
SOURCE: horizontal line across middle of screen. screen
Anytime you get lines on the screen that means the lcd is bad and needs to be replaced. As far as the flickering problem is concerned that can be a problem with the lcd and that would go away as well once you replace the screen or it could be the inverter which supplies voltage to the lcd and its a little board that is underneath the lcd.
Posted on Jul 05, 2009
  • 6 Answers
SOURCE: Toshiba 27
Check for open capacitors in vertical output circuit I believe 47 uf.
Posted on Aug 31, 2009
Tcl TV has black lines and coloured broad line at bottom , can it be fixed DIY ,if so , how ?
Hi, it seems an issue with LCD panel or video processing board, if you have knowledge about Electronics you could fix it, but if not the best choice is to contact a TCL Service center or a qualified TV service technician.
Jan 05, 2018 | Televison & Video
I have a Panasonic TC-P50G10 television that now has numerous small horizontal black lines. Can you advise?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 11, 2016 | Panasonic TC-P50G10 Plasma TV
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
Three coloured lines appered on the screen - no picture
If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
easyab
Apr 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
Re: KDL-40S2000 black horizontal lines
If you have a horzontal black line (left to right) panel is bad.
Sep 04, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Horizontal lines
Depends on whether the "lines" are colored or just blank areas missing in the print . If it is blank areas , then most likely the laser scanner is dirty and the glass needs to be cleaned . If it is colored lines , then you most likely have a defective drum .
Jul 18, 2017 | HP LaserJet 1500L Printer
Toshiba 32AV615DB 32-Inch Lcd Tv Dvb-t Freeview Hd Ready 1366x768 Logo
13 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
