Question about Nokia 5200 Cellular Phone
8007045d error i have error 8007045d
Error 0x8007045d
use kill disc its a free program it will erase all data on hdd then boot from cd/dvd rom drive
Dec 21, 2013 | Computers & Internet
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
When watching a film I get a status code: 69-8007045D, the film I am watching today is one I have seen on my xbox before. This has been happening alot recently, What can I do?
Its a codec problem, basically how the xbox 360 converts the film to be able to play it on there. Is the xbox connected to the net, as it will automatically download the needed codecs
have you tried updating to the newest dash
Mar 10, 2011 | Microsoft Xbox® 360 Core System Console
Whenever i try to do a windows update it always fails because Error code 8007045D comes up, What should i do to fix this?
Hi Mapx,
The error code that you have mentioned has something to do when the target machine (your PC) actively refuses connection to the necessary server. It seems to be a firewal issue. Check your firewall settings if anything is disallowed. Also make sure you have sufficient RAM and HDD space and also that your HDD is not corrupt i.e. it's free of any bad sectors.
Try each of the above and I feel it should work. Also let me know the results i.e. what you did and how your PC reacted to your steps/commands. Good luck.
Nov 05, 2010 | Computers & Internet
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
I have windows vista when it goes to update , get error code 8007045D
Okay you need to scan for viruses first. Something is preventing you from updating if all else fails back up immportant files and dump the system and recover...
Apr 23, 2009 | Toshiba 42HL167 42 in. LCD Television
69-8007045d
I just started having the same problem and i solved it in less than 3 minutes. If your hard drive is on any sort of USB extender it will not work. You to have a USB cord straight from the Xbox to the hard drive. The reason for this is that the video signal is not powerful enough to be interpreted by the Xbox
Apr 23, 2008 | Video Game Consoles & Games
How to make it play the movie
I had the same problem playing video from a data disc, code 69-8007045d. I made the exact same video file play by (1) adding .avi file extension to the file name (i.e. "videofile" renamed: "videofile.avi") and (2) putting it in a folder with the exact same name (videofile.avi). Same video file, didn't have to transcode to .wmv which degrades vid quality. Simple solution, but it worked. This is also the key to displaying a picture file as the icon instead of the generic "filmstrip" pic that displays by default. Just name the picture file the same name as the video and folder (i.e. "video.avi"). This has even worked with divx and xvid encoded videos when I've tried. My guess as to why this happens is that MS doesn't want to be legally or financially responsible for their hardware being used to play protected content, which is also why the status code 69-8007045d doesn't appear anywhere on their official website. Good luck.
Jan 19, 2008 | Microsoft Xbox® 360 Core System Console
My mp3 player wont turn on and my songs are gone
First, try uninstalling and reinstalling the software.
If that fails:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Sep 04, 2006 | Philips SA-177 (512 MB) MP3 Player
Nokia 5200 Cellular Phone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
