I have a problem with Pioneer M-EV51, power problem
When you plug the set the red light power indicator turns on then if you push the power button to turn the set on from standby mode it does not turn on. after a few minutes I tried to turn on again the set, the display on the tuner blinks and so the red light power indicator also blinks. I can also here a clicking sounds ( I guess its coming from the relay) then the power turns off again. Any solution for this? Thank you in advance!
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Short circuited component/s; IC etc: at its audio output section circuit. Contact any service technician. Gopakumar Gopalan Google
Posted on Mar 22, 2014
Hitachi l37v01ua won't turn on from standby mode.....HELP!!!!
when in stand-by mode then red light's blinking. Try to turn it on not from remote but by pushing a button on the set.
Apr 26, 2015 | Televison & Video
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
I replaced the power board on my Scott TV LCT37SHA. when I press the power button the red light blinks as I push it. if I hold down the power button it just blinks until I let it go. please help!!
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jan 18, 2015 | Scott Televison & Video
I got a used LCD1932 Lloyd's TV/Monitor. The top has a standby button, turns it on, but u hit same button to turn it off, it has red standby light that stays on, does that mean it's always on standby
It's normal; if the set do not show a screen at this time. The red light indicates that the set is in standby mode, and it will off, when you hit the standby button again, and the scree will get live.
Oct 15, 2014 | Televison & Video
Pioneer M-EV51 surround problem.
TRY CONNECTING THE RCA JACK (RED,WHITE) AUDIO
INPUTS. MY GUESS IS THAT IT WILL WORK THAT WAY,
AND IF IT DOES CHECK ALL AUDIO SETTINGS ON BOTH
AMP & TV PCM digital audio / LPCM digital audio (LIMITED)
MAYBE BAD HDMI CABLE. SEEN IT SEVERAL TIMES B4
Nov 14, 2013 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Standby mode
Standby power supply runs 7/24 and this should indicate it is not allowing main power supply and hence the set to turn on= short someplace is most likely issue.
Does red light blink and in a sequence of blinks?
Apr 23, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
When i plug the reciver in with nothing hooked up no cables no speakers nothing i push the power button and it will flash a few times then it will go back to a solid red light i cant get it to do anything...
I have the same throuble about this >Pioneer VSX-D812 and in Manual exist the next section:
Chapter 10:
Additional information
Troubleshooting
If the STANDBY indicator blinks and the power shuts off
automatically, take the unit to your nearest Pioneer authorized
service center or your dealer for servicing.
Feb 20, 2011 | Pioneer VSX-D812 Receiver
I have a Pioneer PDP-5030HD plasma and the plasma display does not turn on. The standby/on power indicator light on plasma display is blinking red (after turning it on with my remote, it turns green for a...
First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
Oct 25, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
