Question about Hotpoint Washing Machines
F-1 the washing machine was left without or little watter in it
  • 957 Answers
There is a short in the motor modgule and you will need the right equipment to find it
Posted on May 31, 2014
Hi i have an LG fizzy logic 13.0kg automatic washing machine and just noticed that the water intake does not stop when it gets to it's specified level. how do i fix this?
The water level sensor is a pressure sensor that reeds a vary low pressure inches of water column. There is a little clear plastic tube (hose) that runs from a hose barb on the bottom of the outer tub upto the control panel. As the water rises in the tube it also rises in the little plastic tube water seeks it's on level. This compresses the air in front of it up to the pressure sensor when it reaches a pressure that corresponds to the level that is set it turns off the water if this tube has come loose has a hole or crack in it the air won't be compressed and the water will never turn off. Sometimes after washing bedding or other bulky loads during the spin cycle it will be out of balance enough to cause it to pull that little plastic tube off. If this is the case all you need to do is make sure that the machine is empty of all watter and push the tube back on.
hope this helps. Good luck.
Bob
Sep 12, 2017 | LG Washing Machines
Hello.i have problem with my washing mashine whirlpool aqua steam 9769 B when its strat to pump out a watter its have a intresting sound.washing when finisht is good no left watter inside. First i soat...
Clean the filter/pump cover, you probably have some gunk the pump drain which may have made its way to the impellor. There is usually a panel on the front which folds down and behind should be a large screwed access. Take this out but be aware water will also leak out. clean it and check pump.
Jun 17, 2014 | Washing Machines
How to clean the watter tank
It is good to wash it with mild soapwater and rinse well afterwards. To be certain that you will not get any soap in your coffee, let the water tank run once without any coffee. Kolbrun
Sep 23, 2013 | Coffee Makers & Espresso Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Low watter on wash cycle is there a setting to add more watter to the wash cycle
Try checking the pressure switch. If adjustments are there try. Otherwise you have to check with another switch assy.
Try cleaning the small water hose connected to the switch assembley body.
Mar 30, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washing machine is not stoping puring watter in the moment of wash
The water inlet valve needs replacing.
Over time they lose tension on the spring and the seal wears out cause the inlet valve to constantly let water in.
Hope this helps!?
Jun 26, 2009 | Washing Machines
No water coming into machine
you might have a clog, or maybe you didnt turn the water on. turn off the water and disconnect the hose get a bucket and turn the water on a little bit if watter comes out try inspecting the water hose in the washing machine and see if something is clogging it
May 08, 2009 | Indesit W 123 Front Load Washer
Pump won't stop
ur controler most probabley gone
Oct 02, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
