Question about Whirlpool Heating & Cooling
F2 error in Wasr18k20
Compressor starts and automatically turns off before switching off
Why does humidifier function shut off after 45 seconds?
bacause of the following reason
.Timing defrost by turning off:
When defrost sensor temperature defrost temperature (Parameter F2) and at the same time the defrost
interval time reaches the set value F3 then can enter to defrost, the fan will turn on, the compressor and
heater will turn off.
After worked a defrost interval time (Parameter F3) time, it will enter the stop mode automatically and
compressor will turn off.; after a defrost time(Parameter F1) will exit the defrost mode and enter to
automatic temperature control mode.
Mar 05, 2015 | Humidifiers
F2 error code
An F2 error code means usually that you have a flow issue in your hot tub or you have a part malfunction. The best thing to do with an F2 error code is to go through a trouble shooting diagnosis. Start by cutting the power and letting the unit cool down and then do a reset of the equipment. If that does not fix your issue then do a water flow check, clean your filters, release air locks, remove debris from your intakes and returns. If your problem still remains look to replace or repair fuses, heater elements, or your circuit board. I hope this helps. http://www.thecoverguy.com/backyard-blast/f2-error-code-trouble-shooting/
Nov 09, 2013 | Great Lakes Spas Pool & Spa
Dawalance 1.5 ton split ac shows F2 error and compressor dods not start. Pl guide the solution.
AC switch on and open AC front panel and you see the Auto button in panel in right side button push hold 5 seconds, FC error resolved :)
Aug 22, 2013 | Heating & Cooling
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
The computer is not starting automatically eventhough the power button is switch on. The screen only shows the message" In touch with tomorrow", Theres two choices to press,F2 for Set up menu and...
Remove the Power cord and battery
Hold down the ON button for 30secs (dispersing all internal voltage)
Plug the power cord back in (leave the battery out for the moment)
Turn on
Does it work?
If so, shutdown normally
Re-insert the battery
Turn back on
Mar 16, 2011 | Toshiba Computers & Internet
My split unit air con will switch off automatically every 10 minutes and the lights will blink. It can only be turned on again if the power is switched off from the mains.
May be in indoor screen there is some error code. Don't worry. I try to solve it. Normally after 3 minutes compressor will start. If compressor amps gradually increase due to condenser block or less rpm of fan motor. Please ensure with amps meter for increasing ampere It will run just 10 minutes or up to the maximum running amps and get tripped. Service your indoor and out door and check. . Is it helpful?
Dec 28, 2010 | Electrolux Heating & Cooling
Kenmore 110.6807 Dryer won't run properly. In diagnostic mode, everything checks out, Dryer runs and heats. Getting F2 error in normal and diagnostic modes. I disconnected P5 and checked the switches on...
One of the first things to do when a F2 error code appears is to perform a simple reset. To do this, turn the dryer off and disconnect power to the dryer. Wait 30 seconds to one minute, restore power and turn the dryer on. Choose a new dryer cycle and push "Start" to begin. If the error code does not return to the display, the reset was successful and no further action is necessary. Hope this helps.
Read more : http://www.ehow.com/info_12001824_kenmore-elite-dryer-troubleshooting-f2-error.html
Dec 06, 2010 | Kenmore Dryers
How do I make the AC compressor turn on to fill the freon when it is empty?
Find the low pressure switch and unplug it and take a wire and connect both wires together tying the circuit together this should automatically turn the compressor on. Make sure the switches inside are on high maximum blow and A/c switch is on. You could also run a wire fused directly to the wire going to the head of the compressor. Usually once you start putting freon in as long as everything is working perfectly it should automatically kick in with jumping it over or putting direct power to it.
Oct 11, 2010 | Chrysler Sebring Cars & Trucks
A black sitch that says off or automatic what does this do and is this an off switch to turn the compressor off
If you are referring to an electric air compressor, and not a chain saw, then yet, the Off position turns the air compressor off until you want it to run again. Automatic will start and stop the compressor as the air pressure drops / rises in the tank.
Sep 21, 2010 | Garden
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Heating & Cooling Logo
13 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
