Question about Brother LS 2160 Sewing Machine
My Brother LS 2160 is threaded but not stitching
I have done the upper threading following the instructions but it is just not stitching at all. The thread isn't catching. I have tried both straight and zig zag modes (the latter is what I need to do), and only 1 time will the thread actually stitch. I'm using the needles that came with the machine and done both thin fabric and cotton rope (latter what I need to stitch). Could it be that I'm using the wrong thread to the needle? I'm using the needles that came with the machine. Thank you! I'm very much a beginner here :)
    Problem Solver:
  • 7 Answers
Hi there Kathryn... when you load/thread the top cotton through the machine.... and then through the eye of the needle.... do you also load the bobbin case... or is it already in there and loaded as per instructions... ? What I normally do... is load up the bottom and top threads first.. making sure to put the top thread through the needle and make the thread end go through and behind the 'foot'... when placing on fabric to try... I make sure to load the fabric... with the top thread's tail going out through the presser foot and behind your foot.. sometimes.. if its the thread (some machines don't like certain threads)... I will manually (wind the right hand wheel) so that the machine does a few stitches.. before I use my foot pedal!.. I have both a serger/overlocker... and a Brother 8500 (sewing/embroidery machine).. I have been sewing for over years now...
You will need to change your needle... when you've used it for more than 6-7 hours continuously.. OR you notice that the stitches are not as they should be... in your fabric...
Posted on Mar 22, 2014
SOURCE: Brother LS-2125 Upper Thread Snapping
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Posted on Mar 09, 2009
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Mimito7
  • 128 Answers
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Most machines need to have the thread extend to the back of the machine in order not to come unthreaded.
Posted on May 21, 2009
  • 9 Answers
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Dec 31, 2016 | Brother Sewing Machines
My brother LS-2125 will not do zigzag stitch needle moves from side to side but only does occasionally zigzag
If you are saying the needle zig-zags but the upper thread is not catching the bobbin thread every stitch, then it could be a timing issue.
Jul 08, 2016 | Brother Sewing Machines
Why does upper thread break when I try to sew zig zag stitch?
Your tension sounds too tight, try lowering it on the upper thread. Or you may be using a cheap thread which frays easily and frays in the needle. Try using a longer zigzag to see if that works. Is straight stitch smooth?
Nov 02, 2015 | Brother Ls-2125i 10-stitch Portable Free...
I am having issues with threading my machine. I have followed the instructions but every time I sew on the machine the thread on the top sews correctly but underneath the cotton gathers up. What am I doing...
If the thread is bunching under the material it is the top tension. While threading the machine be sure the foot is in the up position until you are done threading it. If you have tried that and it still bunches you need to tighten the tension a bit at a time until it starts sewing correctly. Be sure you are starting with a clean machine and that the thread is not too large for the needle ....
hope this helps.
Nov 25, 2013 | Brother LS 2160 Sewing Machine
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
The underside stitch is a mass of loose thresd
A mass of loose thread on the bottom of the fabric most likely indicates a total loss of upper tension. Remove the upper thread, raise the presser foot and rethread the machine. Make sure that the upper tension knob/dial is around 5. If you still have a problem, let me know what brand and model you have.
Jun 27, 2009 | Singer Sewing Machines
Feb 12, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother won't sew
My Brother machine is sensitive. You may have already done this, but...
Rethread the top, following diagrams and instructions precisely.
I have taken the front off the machine to find a nest of thread in the upper part of the machine.
Remove the bobbin and bobbin case, and reseat both.
Check the needle. If it is bent even slightly or not seated well, the whole needle shaft can lock up.
FAQs Troubleshooting LS 1520 Others Brother
Aug 11, 2017 | Brother LS-1520 Mechanical Sewing Machine
Brother LS 2160 Sewing Machine Logo
146 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
