Question about Sony Televison & Video
Sony wega kv-DA29M86 standby light blinking 5 times. whats the problem?
Picture color is not good as past and it has some noises when use AV
    Top Expert:
  • Sony Master
  • 74,630 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Mar 22, 2014
pgh_pa_guy
  • 2992 Answers
SOURCE: my 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Posted on Feb 17, 2009
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 8457 Answers
SOURCE: sony wega KV-36FS13 standby light blinking 5
Ur power ic inverter board is dead.
U need a new one.
Posted on Aug 23, 2009
  • 4090 Answers
non of the blinks are good but here is yours
\5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
also not a DIY
Please rate my help++++Thankis for using FIXYA
Posted on May 20, 2010
Sony wega 51" standby light is blinking 5 times repeatedly. what is this code for?
The picture tube is getting close to failure. Has the picture tube been replaced before? If it hasn't it is probably about due the Vegas were great long lasting T.V. sets but after about 15 years need a new picture tube.
Jan 15, 2013 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega KV-36FS13 standby light blinking 5 times. no pic.
also not a DIY
May 19, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinition WEGA KV-32fs120 32" (no picture)
If the standby light is blinking 5 times then repeating, it is likely a problem in your picture tube or related circuitry. Other possibilities include the "Jungle" IC which takes care of the video, chroma and deflection processes and is a bear to replace. Either way, it could be an expensive repair.
Feb 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
