Question about Hoover HMA28K / HMA28KX Bottom Freezer Refrigerator
Hma28k too cold
Motor runs continuously
2011 tiguan engine cooling continues to run
The relay that powers the motor is stuck in the on position. Or the sensor that controls the relay is fubar. Till issue resolved simply disconnect the fan when ignition is off or hook up a manual on/off toggle switch.
Jul 24, 2017 | Cars & Trucks
'87 Yamaha ProV 50: Will cold start and idle well. After a full throttle 1-2 min run will begin & continue running very rough near idle. Will die without addtl throttle imput.
Hi Roderick:
I'm not familiar with your engine configuration, but on some of the older bikes, vibration eventually can cause a wire to break in the coil. When the engine is cold, the wires make contact and it runs, but as soon as it gets hot, the connection is broken or compromised and the spark quits or drives you crazy.
Since your bike runs when cold and quits when hot, I'd be looking for electrical rather than fuel problems.
Hope this helps.
Sep 09, 2015 | Yamaha Motorcycles
Motor starts then dies several times when cold
Sounds like the cold start solenoid. It is designed to keep the engine running at a set RPM until it reaches a specific engine temp.
Nov 22, 2014 | 2003 GMC Sierra 1500
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
My new Bosch B26FT70SNS fridege which i got delivery yesterday morning compressor motor won't turn off. Since yesterday afternoon around 5pm until now 11am. More than 18 hours continue running, the...
HI JAMES.ummmm new bosh...should work.if not and motor running cont.then it sound to me like is out of refrigerant or motor faulty.check condenser unit.should hot.if cold call under warranty or replacement i would say.good luck Ali
Jun 30, 2012 | Refrigerators
My fan runs continually, even when I switch the thermostat to 'off' between the heat and cold setting.
There would be a relay,or transistor malfunction in the unit that controls the fan motor.
Apr 16, 2012 | Heating & Cooling
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Both fridge and freezer aren't getting cold enough in my Maytag Fridge
if they are both cold, but not cold enough, one of two likely scenarios, one minor, one major. the major one, you haev a sealed system leak of refrigerant, several hundred dollars to repair.
the minor, your condenser fan motor is not running, its job is to cool the compressor, if its not cooling the compressor, when the compressor gets too hot, it will shut itself down, while the fridge continues to run. when this happens, the unit seems fine first thing in the morning, but by evening it seems less fine...while everyone sleeping, doors have been closed, allowing unit to "catch up". replace fan motor.
Feb 27, 2010 | Refrigerators
After a black out the air isnt cold and the motor doesnt run
Check :
1. If the main fuse is good
2. check outlet for power
3. Check cable
4.Check for the relay
5. Check the motor for continuity using ohmmeter
6. try the direct running without relay
if run at 6
replace the relay
if not the compressor is to be suspected
All this operation have to be done by a professional only.
Mar 11, 2009 | Mitsubishi Heating & Cooling
Kenmore Elite HE 5t
Low or no water supply, hot or cold side or water pressure switch not switching over to indicate fully filled though if this happens drain motor will continue to run continuously while f-20 flashes
Jan 15, 2008 | Kenmore Elite 45986 Front Load Washer
Hoover HMA28K / HMA28KX Bottom Freezer Refrigerator Logo
16 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
