Question about Sokkia B Series, B30 Engineers, Construction, Automatic Level 2
TECHNIQUES IN LEVELLING BUBBLE
EASY WAY
How do I replace the headlight leveler motor on a PT Cruiser?
LAMPS/LIGHTING - EXTERIOR PT
HEADLAMP LEVELING MOTOR - EXPORT
REMOVAL
(1) Remove headlamp unit
(2) Disconnect headlamp levelling motor electrical
connector.
(3) Rotate levelling motor one quarter turn counter clockwise.
This will free levelling motor housing from
the headlamp unit.
(4) Pull levelling motor straight from headlamp
unit. Significant force will be required to unsnap
motor control arm from lens reflector.
NOTE: The headlamp levelling motor control arm is
snapped into the lens reflector mechanism very
securely. Use a firm, steady pull to disengage motor
arm from reflector.
(5) Remove levelling motor from headlamp unit.
INSTALLATION
(1) While holding headlamp reflector assembly
still, push levelling motor until control arm is fully
seated into reflector mechanism. An audible "snap"
will be heard.
(2) Push and rotate levelling motor one quarter
turn clockwise to lock motor to the headlamp unit.
(3) Connect headlamp levelling motor electrical
connector.
(4) Install headlamp unit in the vehicle Locksmith Buffalo Ny 24 Hour Locksmith in Buffalo Ny 716 249 2944
May 17, 2016 | 2004 Chrysler PT Cruiser
Where is the fill reservoir for my self levelling system on my ford exployer 1999
I can't answer your question but reading the vehicle handbook propably could.
If it is an engine driven pump it should be easy to find and might be on top of the pump or at the end of the pipes leading up from it.
May 02, 2016 | 1999 Ford Explorer
Levelling suspension inactive showing
Check the fuses for that one to be blown.
Mar 04, 2014 | 2005 BMW X5 4.8
I would please like a manual for the simpson eziloader front loader washing machine
45s558e_lr.jpg A 5.5kg capacity front load washer with a stainless steel spinbowl, 8 wash programs, variable spin speeds, 2.5 star energy rating and a WELS 4 star water efficiency rating (56 litres). General Specifications Colour: white Overall Dimensions (Check installation guides in downloads for exact dimensions) Overall Height: 850 mm Overall Width: 600 mm Overall Depth: 630 mm Key Specifications and Features Capacity: 5.5 kg Energy star rating on old scale: 2.5 stars Spin Bowl: Stainless steel Wash Programs: 8 Water efficiency star rating (WELS): 4 WELS Water consumption: 56 Litres Other Specifications Door opening - Large: 300 mm Door opening angle: 165 degrees EAN: 8853328005026 Variable spin speeds: 800,650,500 rpm Other Features Colours 40/ Colours cold: Yes Cotton 60 / Cotton 60 eco / Cotton cold: Yes Cycle start/pause button: Yes Delicates 30 / Delicates cold: Yes Extra rinse: Yes EZILoader: Large EZILoader doors makes loading and unloading your washing easy. Levelling legs: The levelling legs may be adjusted if the floor is not level, to ensure correct operation of the washing machine Pre-wash: Yes Pushbutton electronic options: Yes Quick Wash: Yes Rinse/ Drain / Spin: Yes Rotary Electronic Controls: Yes Wool 30: Yes Warranty Details 2 years from the date of first purchase (3 months for commercial applications) and subject to the conditions set out in the warranty card accompanying the product when purchased.
Aug 06, 2011 | Washing Machines
How do i replace lights on bubble tubes? They bubble but no lights.
You can order bubble tubes and damaged front plastics from Deer Park Dist (618) 427-3761. Once you get the parts, remove the back of the unit. You will be able to see all the screws which hold on the front plastics. Removing the screws and the plastics to get easy access to the bubble tubes. A long screwdirver is helpful. The magnets in the speakers will grab the screws and the screwdriver from you.
May 12, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
2005 jaguar xtype how do i adjust headlights
If I am understanding your post, I believe you do have a levelling
system and it should be near your light switch on the dash. It is
the type of switch that you depress first, it then springs out and
you turn the small knob (just like your instrument panel lights
adjuster next to it.) What you do not have perhaps, if your car is
not fitted with HIDs (high intensity headlamps), is the automatic
levelling system which is a legal requirement when HIDs are fitted
due to the high power of the lights....
if you don't have a self-levelling system then you'll have a manual
system, operated by a knob under the light switch so that you can
adjust to compensate for a heavy load in the rear of the car.
Mar 26, 2010 | 2005 Jaguar X-Type
The levelling light flashes can hear hissing
you have a air line or air valve that has went bad or a bad air bag, find the air leak and you will find the problem. it may just be a line. each wheels has a leveling lever that airs up each wheel bag if air leaks out it will cause the whole suspension not to operate and it will damage the car and will cost you big bucks if you don't fix it. if it's just a hose you may be able to cut it and make it work or you will have to buy a new hose with ferells to rehook the new line up.
Nov 21, 2009 | 1998 Cadillac Catera
The fridge is unlevel front to back. The front is relatively too high. How do I level the beast?
The front should be a "little" higher than the back, in order that the doors will close softly when pushed past a certain point, and to assist in sealing the door to the cabinet. There is a levelling mechanism on the front rollers, turning a screw or bolt head clockwise will raise the rollers and counterclockwise will lower the rollers. If no rollers, then post type feet that screw in and out for height. Most have rollers in front and these can be adjusted with the screw or bolt that you can see in the front behind the lower cabinet cover. It should lift and pull straight out to remove, and you will then see the adjustment bolts or screws. You should be about half a bubble out of true level for the doors to seal well and close softly.
Sep 26, 2009 | Samsung RF265AA Bottom Freezer French Door...
Zanussi ZDT6252 Levelling
After having the same problem I resorted to sawing off the rear foot, only to then discover that there is a crosspoint screw on the middle at the fron that winds up or down the rear foot.
Nov 03, 2008 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Sokkia B Series, B30 Engineers, Construction, Automatic Level 2 Logo
80 people viewed this question
Top Sokkia Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sokkia Retail Supply Expert? Answer questions, earn points and help others
