Question about Vacuums
Drier cold remove top
    New Friend:
  • 4 Answers
We used to have a saying in the automotive repair business, and it went like this. A lack of information or incorrect information about the unit you're trying to repair and the parts you need will ensure that you get the incorrect part for that unit every single time. You've given us next to nothing to help you with. We'll need at least a model number and make of the unit. Then maybe we could help with a solution.
Posted on Mar 23, 2014
Where do I get drier sheets for my dyson to get rid of smell?
Attempt to eliminate the odor rather than mask it it. Replace the filters and clean the cyclone chamber and dust bin.
Mar 14, 2015 | Dyson DC40
How do I get a stuck top off a Scunci ss1000 steamer?
try putting it in a freezer for awhile cold makes metal shrink and that may loosen the top .
Dec 07, 2017 | Scunci Ss1000 Steamer Irons/Steamers
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
How do I pop the top off to replace level adjustment lever.
Turn the machine over (with the handle released). Remove the 4 screws (2 on each end of the cover over the brush). Remove the cover. There are 2 screws, deep in the machine (behind drive train wheels) remove the screws. With the machine in the same position, note 2 plastic clips located on either side of the top cover. Release the clips using a slotted screw drive.
Nov 28, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Machine stops working after about 15mins of use.Doesn't feel hot and fuse not blown.Any ideas ??
This is most likely due to a dirty filter. Cleaning:
Turn off and unplug the machine.
Press the release button on top of the back of the powerhead.
Remove the filter housing.
Separate filter from housing.
Rinse thoroughly the following items in cold water: foam, cage, and cloth.
Repeat until the water runs clear.
Air dry for at least 12 hours before reinstalling. Make sure it's completely dry.
Mar 01, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
OLYMPIA ONE (NO CHOICE ON PRODUCT LINE)
Usually the older hose get replaced, they just weren't made to be repaired, if it looks like something that will come off, then try either warming the sleeve up with hot water or a hair drier to see if you can work it off after it has warmed up.
Apr 26, 2008 | Electrolux Central Vacuum
ELECTROLUX OLYMPIA ONE HOSE
Apr 10, 2008 | Vacuums
Poor suction
i had the same problem and moter cutout for over heating.i removed everything removable to see blockages i found a ball point pen and wood shavings.i cleaned every part possible including the rubber gaskets.also cleaned the bubber gasket in the waste bin.[mine is a 07] still poor suction. i removed side filter washed it in "warm water" and washing up liquid[dyson say to use cold water] the rinsed out in cold water,left the filter over night on a news paper nr the radiator. problem solved..fantastic suction and no over heating.hope this will help
Apr 02, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
