Question about Brother XL-5340 Mechanical Sewing Machine
Bobbin thread bunching up
I have a brother XL-5340. It was sewing fine; then the next time I tried to use it, it started skipping stitches and the thread from the bobbin started bunching up and becoming a huge knot. I just had the machine serviced a few months ago. What can I do to fix this?
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
Posted on Dec 10, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
Posted on Sep 19, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Posted on Mar 31, 2009
0 characters
1 Points
My bobbin isn't working properly it clumps up...
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
How do I sew denim and heavy fabrics?
Why is my bobbin not winding evenly?
Why won't my machine pick up the bobbin thread?
Why is my machine skipping stitches?
Why is the thread looping/bunching under my fabric?
Why is the thread looping/bunching on top of my fabric?
Why doesn't my stitch pattern match what is on my machine?
How often should I oil my machine?
What types of thread should I use?
I can't see the take-up lever? ,,
May 22, 2015 | Brother XL-5340 Mechanical Sewing Machine
Bobbin thread loops
try adjusting the top tension, one number or letter at a time on a
piece of scrap fabric till the bobbin stitches don't loop any more
here is a free manual just incase you don't have one, just click on
the link
Nov 12, 2012 | Brother XL-5340 Mechanical Sewing Machine
Thread bunching and bobbin winder quit
This sounds a lot like you've forgotten to lower the presser foot. (this leaves the tension discs open and causes serious issues below the material.) Double check that and if still having issues post again.
Nov 03, 2012 | Brother SE-270D Computerized Sewing...
Suddenly my brother xl-2220 is sewing strangely! The top stich is fine, no tensio issues, but when I look at the bottom stitch it isn't right! The stitch is very loose and looks like the pattern a snake...
totally rethread, and do this test, rethread with the presser foot up, pull the thread it should feed smoothly, now lower the presser foot, pull thread, it should barely move. This will seat your thread in the tension discs, Also, don't be afraid to change your needle often.
Apr 21, 2011 | Brother XL-5340 Mechanical Sewing Machine
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother XL-3030 Electronic Sewing Machine
I have to contantly adjust the thread tension because it won't stay. I can only sew for a bit before the it is out of whack and tangling/knotting up thread underneath.
If you have the bobbin correctly installed and are threading the machine with the presser foot up, then the problem could be the machine needs to go to a Brother dealer for service.
Take samples of the stitching problems. It could be the tension, but it is probably the alignment needs to be adjusted.
Mar 28, 2010 | Brother XL-5340 Mechanical Sewing Machine
Machine not sewing
Have you checked that the tiny screw in the bobbin is not loose, sometimes this creates this problem for me or if the bobbin size is incorrect.
Dec 13, 2008 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
407 people viewed this question
Top Brother Sewing Machines Experts
Bargain Box
Bargain Box
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
