Question about LG Washing Machines
Wd 12396 tdk
Hi ,my LG washing machine was working well for 20 months.Only few days back it got stuck at the spin point.How to solve this problem??..
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Probably faulty switch knob, need to replace the switch or else you might burn out your motor if it shorts out.
Posted on Mar 22, 2014
Brussels
  • 16 Answers
SOURCE: Error code SE on LG washing machine means what?
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
  • 4 Answers
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Posted on Jun 07, 2010
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
LG tromm washer is stuck at 22 minutes and just keeps washing and spinning
Sometimes the firmware or program in the microcontroller of the machine gets scrambled due to electrical spikes or fluorescent lamp frequencies in the vicinity of the machine.
Unplug the mains supply for about 10 to 20 minutes and retry, this will normally solve the problem as the firmware program resets itself.
Dec 14, 2015 | LG Washing Machines
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
I have a LG Front loader machine, WD-10485TP displaying CL error code. Please help.
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it. It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
If problem remains unresolved, revert and i would tell you few more methods.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 22, 2011 | LG WD-1280FHD Front Load Washer
Hi I have an LG WD-1290RD and it won't spin at all - any ideas?
Possible that the main program controller is faulty if there is no output to the inlet valve or the motor. If not the motor can be stuck or the motor start capacitor is faulty.
Please check on these tips.
Mar 29, 2011 | LG Washing Machines
I need the manual user of LG washing machine WD TDK
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download a manual for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 11, 2011 | LG WD14121 Front Load Washer
I have an lg 5kg washing machine WD-80264NP which stops after washing for while.it doesn't spin. what could be the problem?
Ur timer switch for washing/spinning is broken, there are contact points on that timer switch, the part of SPiNNiNG is not functioning!
Let a technician check on that, and might as well replace it!
Nov 29, 2010 | LG Washing Machines
LG WM-2277HW Front Load Washer CE error message
Hi
The CE is for Child lock system error. i just had one on my WD-1049C. It is a system used to prevent children from pressing the buttons.
the way I fixed it on mine is by holding the temp button and the option button at the same time.
Jun 28, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
51 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
