Question about BullGuard Internet Security
Error code: 74
How to fix it
1 red light e 74 code
E74 is an error related to video. It's either:
  • Bad video cable
  • Bad graphic chipset issue
Try a different video cable, unplug and plug it back in to make sure the video cable is seated properly. If it's neither of these issues, the only thing to do is to contact Microsoft's customer service and get it replaced/fixed.
May 27, 2010 | Microsoft Xbox 360 Console
My xbox 360 comes up with an error 74 code how can
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
If your still under warrenty send it to microsoft, if not you could try the towel trick (i dont recommend) or bring it to someone that can repair it for you (try cr@igs list)..
Mar 08, 2010 | Microsoft Xbox 360 Console
My 360 received an error code 74 what does this mean and how can i fix the problem without sending my 360 in for repair
4TH LIGHT ON ERROR CODE 74 SYNC CODE 1022
Things DONE;
replaced AV cable
cleaned contacts
WHAT NOW !
Dec 22, 2009 | Microsoft Xbox 360 Console
How do i fix the e 74 problem?
this is what that code means i dont think you will have much luck fixing it yourself tho: E74: I/O Hardware Error - HSIO related, could be crc error, or many things: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. Microsoft covers this error under their 3-year warranty, this is availble to anyone who hasn't modified their console. contact MS to get a free replacement console before attempting to fix this yourself. Failing that this error In some cases it is a problem with the GPU and may be repairable by doing the x-clamp replacement (see error 0102)
Sep 30, 2009 | Microsoft Xbox 360 Console
Hello, i have one red light with an e 74 error.my
Do the X clamp fix. I have repaired countless consoles with this fix that had the E74 error
Aug 11, 2009 | Microsoft Xbox 360 Console
E74
The E-74 error is also due to overheating and the RROD fix also cures this fault, hope that helps :)
Nov 11, 2008 | Microsoft Xbox 360 Console
Console
error code 74 is
74: AV cable Error - There is a problem with the AV cable, try using a different AV cable.
hope this solves your problem
Maxicube
Feb 10, 2008 | Microsoft Xbox 360 Console
Error 74
error code 74 is
Maxicube
Error 74
E74 is an error that has two possibilities one is that your AV cable has gone bad. Swap it out and see if that fixs the issue.
If that doesnt work then you need to contact MS, your GPU / Scaler chip has gone bad and MS needs to replace it. There is no fix for this like there is for the red ring error. hope this helps
Jan 04, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
120 people viewed this question
Top BullGuard Computers & Internet Experts
David Payne
David Payne
Are you a BullGuard Computer and Internet Expert? Answer questions, earn points and help others
