Question about Asko W6021 Front Load Washer
Foreign object in machine - Asko W6021 Front Load Washer
My washer machine hitachi nw -d8gx code c8 what going on?
C8 indicates that the lid cannot be locked.
Is the lid closed?
Are there any foreign objects in the lock?
Check that the lid is completely closed.
Check that there are no foreign objects in the lock.
Link to users manual.
http://www.hitachi-th.com/hitachi_new/Download/SF-140SV_EN.pdf
Aug 03, 2014 | Washing Machines
Tajima embroidery tech support
Did you recently break a needle while using the embroidery machine? Check for foreign objects (like part of a broken needle) in the rotary hook. Then press Set to reset the machine. Remember to turn off the machine and then unplug it before doing any maintenance. If there are no obvious foreign objects, the rotary hook may have been damaged by a bent needle. It may need to be replaced.
I hope this helps.
Jun 04, 2013 | Computers & Internet
Every time my machine turn it make a loud squeaky noise and the machine dose not ring out all the water
Hi blare131,
I believe there is a foreign object stuck in your Drain Pump Filter, please check it and remove the foreign object.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 17, 2011 | LG Washing Machines
When the washing machine is draining it starts to make a grinding noise
Hi.
Access the drain filter and check for foreign objects in there. In this model the access for the drain filter should be located at the front bottom of the machine, behind a trim. Other models have the access at the back. Disconnect power, locate access, remove cap, collect water using a container and check for blockage or foreign objects in there.
Regards.
Ginko
Aug 06, 2011 | Indesit W 123 Front Load Washer
I GET A PLS OPEN COVER OFFLINE BUT NOTHING IS
I think the machine is telling you to look inside for a foreign object or scrap of paper:
1) Turn the machine OFF
2) Open the cover
3) Carefully inspect inside for a bit of torn paper, staple, paperclip or other such foreign object - gently clear any problem materials. Do not touch internal parts if possible. Use tweezers for small hard-to-grasp objects.
4) Close the cover, and power ON
5) If the MFC cannot reset itself, or if no foreign material is found, the machine should report an error code, for example "Machine Error XX"
6) From this code, brother support should be able to diagnose and help with your problem
Mar 11, 2010 | Brother MFC 8500 All-In-One Laser Printer
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
The machine has a mechanical
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Error Message: Scan Unable A6
did you get the solution to the problem u mentioned
Feb 21, 2008 | Brother MFC-8220 Fax
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Asko W6021 Front Load Washer Logo
22 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
