Question about Amcor Intelli Trap Mosquito Insect/Bug Killer IntelliTrap
How long a time can I run the intellitrap mosquito trap. I use indoors, can it run all night?
Is it harmful to me if I run it all night, will it damage the unit.
Where can I find information about mosquito nets and accessories?
I found a perfect site that will explain to you almost anything you want to know about mosquito nets and other accompanying http://www.safariquip.co.uk/all-categories/insect-protection/mosquito-nets/choosing-a-mosquito-net/ you should have a look.
Aug 07, 2012 | Camping, Backpacking & Hiking
Does a fan can be an alternative for mosquito net?
A fan is the most common alternative to use in case you don't like sleeping inside a mosquito net, it increases air flow as mosquitos prefer still air however this is a much less effective than a mosquito net.
What are the advantages of impregnated mosquito nets?
The main idea of impregnating a mosquito net is not only to protect you from mosquitos but also reduce the mosquito's population in malaria areas in developing countries. For more information visit http://www.rollbackmalaria.org/
How to make a home made mosquito repellent
This WEB site has home made mosquito repellent recipes.
http://tipnut.com/homemade-mosquito-repellent/
Aug 01, 2011 | Computers & Internet
Koolatron mosquito trap fan won't run.Power to the machine but the fan won't run
I have been experiencing the same issue, and I solved my problem by cleaing the mosquito guts off the side of the fan body and blades with a wet toothbrush. I unplugged the unit and brought the entire head into the laundry room wash tub. remove the screened cup and then you can access the fan from the bottom. It would make life easier if you cut the plastic framing off, but you can reach in with a small toothbrush if you have some patience.
Jun 11, 2011 | Garden
Why do mosquitos like O blood more than the other types of blood then?
Mosquitoes are attracted not only by things like the CO2 that you exhale, but they are also attracted by the odor that are blood secretes through our skin. For some reason that scientists haven't figure out yet Type O blood secretes more chemical "odor" than any other blood type. The interesting thing about all of this is that our genetics will control whether or not we will secrete those "odorant markers" through our skin. For some reason people with Type O blood are genetically pre-disposed to secreting that odor through their skin. Some people genes stop them from putting out any type of odor from their blood at all. This of course doesn't mean that they will not get bitten at all. It just means that their blood "smell" will not help to attract the mosquitoes to them.
So if you are a Type O person, once the mosquito is attracted to you by your CO2, your blood odor will help to make you attractive enough that not only will the mosquito come to check you out, she will also probably land on you and bite you. Type O or not, the best defense against the mosquito is still either staying indoors, using mosquito nets, or using any repellant that contains DEET. This is still the single best repellant agent out there to use against the little blood suckers. As some people can be sensitive or allergic to DEET make sure that you try some of the repellant on a small patch of skin to see if you have any reaction to it before rubbing or spraying the repellant all over your body.
May 14, 2011 | Nintendo Super NES Console
My eState dryer MOD: tedx640pq1 wasn't heating. I replaced the thermal fuse and switch to an indoor lint trap because I suspected that the vent was blocked. Now, the dryer is getting too hot, even on the...
do you clean the the indoor lint trap each time or is it the style you put water in to an bucket? It still has a problem with air flow as it is exiting the unit.
Feb 13, 2011 | Dryers
How long does the battery on the mosquito last? It's not holding a charge stong enough to stay in the air. I'm using radio shack batteries, will energizers give me a stronger charge?
I am not endorsing one brand over another, but I have had better luck with the main brand name alkaline batteries. Just for fun, compare the weight of the Energizers to the R.S., you might be surprised.
Oct 04, 2010 | Radio Shack Indoor Micro Mosquito Rc...
Mother not working
You blew out the motherboard, cpu & ram may have survived, but I would guess that high of a voltage would have fried the mobo
Jun 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Amcor Intelli Trap Mosquito Insect/Bug Killer IntelliTrap Logo
12 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
