Question about Canon Office Equipment & Supplies
I have a Canon iRC3170 photocopier, when it is switched on it shows this error message E0748 - 4150. What is wrong? Thank you.
  • 6 Answers
SOURCE: error message: E00805-0002
Check the main cooling fan (fm1) in the rear center of the copier. is it running? if not see if it is plugged in. I had a kid stick a sucker stick in the fan causing the same problem.
Posted on Nov 23, 2007
spinal
  • 287 Answers
SOURCE: Canon photocopier
Title : E020 Error Code Problem :
When you have followed all the steps from the troubleshooting guide in the Service Manual and still have not resolved the issue, here are some possible areas that might be related.
Solution :
1) Confirm that the toner and hopper sensors are being wiped completely.
2) Check the Gear Train on the hopper assy it may be locked up.
3) A possible bad hopper unit cable. FG5-5016-000. See The Parts Catalog page 620-2 item # 60.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on Jun 29, 2008
  • 82 Answers
SOURCE: when i start canon photocopier ir-2016j , its
Your machine appears to think it's waiting for a file (like an update). Somehow it was put into download mode (only a canon tech would know how to). You need to have a canon technician to either reset the machine or if there is a legitimate problem put it into factory default.
It may be a hard drive error from my experience.
Posted on Nov 29, 2009
  • 452 Answers
SOURCE: My ir canon photocopier shows
if you are changing the machine room from cold to warm, it can causes the error code E100, it's a condensation of the laser sensor. to solve this problem you need change the laser sensor PCB or the laser unit. or try to warm up the pcb sensor with a hot air. look at the picture to identify the laser sensor:
Posted on Dec 18, 2010
RadarRon
  • 398 Answers
SOURCE: MY CANON iR2018 PRINTER COPIER
The error E007 code means that the fusing film is worn out or damaged. Worn out is self explanatory, Damage will generally happens when a jam is cleared incorrectly (forcibly or by sticking something like a butter knife into the machine "Do not laugh, I have seen it!"), You will need to most likely have the fusing film replaced. This is beyond most users, you are probably going to have to get a service center to repair it.
Sorry, but I hope this helps
Posted on Dec 22, 2010
Testimonial: "I called in a service guy and after about an hour, voila, am able to print. thanx RadarRon"
Hi, stationary jam indication with no error code in canon irc3170; why it shows like this. Can enybody help me.
check paper pice in the paper feeding unit and chech p f unit sensor switch may be broken
Nov 20, 2014 | Canon Office Equipment & Supplies
When I turn on my Canon iRC3170 I receive an error code E0748 - 4150. What is wrong?
Mar 13, 2014 | Xerox DocuColor 12 Printer
Error message
load more papers in your printer or copier to start it again.If it doesn't,ask again
Apr 14, 2010 | Office Equipment & Supplies
The screen just shows error E000
E000 code Fuser Error
What model of Canon copier is it?
May 15, 2009 | Canon Office Equipment & Supplies
Error code E007
Canon photocopier IR2016J show error code E007. Please advised me on how to resolve
May 05, 2009 | Office Equipment & Supplies
Canon photocopier
Solution :
Jun 27, 2008 | Canon NP 6050 Copier
ERROR MESSAGE
Yes you have a fuser problem you can try to reset it but more than likely you will need a new fuser or part of the fuser
Contact me if you require more help
Mar 06, 2008 | Canon PC-D320 Copier
Canon D680 (Fax and Photocopier)
1. Press ?additional functions? key. 2. Press ?#? key. 3. Press the ?>? key until you get to number 7. 4. Press ?Set?. 5. Press ?>? key until you get to number 4 (printer reset). 6. Press ?Set?. 7. Select ?yes? if in a fuser error. If this does not work, you will probably need a new fuser unit. Ed
Jan 21, 2007 | Canon imageCLASS D680 Laser Printer
19 people viewed this question
old marine
old marine
