Video card failed, can't see to install another - Catch 22!
Put in another (different model that I had on hand), but no signal out. No built-in video output on back panel. I can't see anything to be able to load new drivers, or even log on. How do I install a new video card when I can't see anything??
    Sergeant:
  • 223 Answers
Try a basic graphics card. or external GPU. or use harddrive on another machine to configure default settings and drivers of new GPU
Posted on Mar 22, 2014
SOURCE: No Video Signal
If you can't use the onboard video and it does POST or the PCI-E video card does show anything, most likely the motherboard is toasted. Apparenty gateway uses real poor quality power supplie and motherboards.
I have the same system, it powers on, but nothing. All I can assume is that the motherboard is bad.
Posted on Jul 11, 2008
mumma_1
  • 903 Answers
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
Posted on Oct 31, 2008
  • 34 Answers
SOURCE: Onboard video has failed..how do I change in bios to video card ?
first install the video card in the pci slot first so that you have access to your monitors screen for you to disable the on board video chip or video card, go to the CMOS setup by pressing del key. once there you can browse through the CMOS setup to disable the on board video chip.
Posted on Dec 22, 2008
Fixe_You
  • 1800 Answers
SOURCE: No video on Dell C521
in this case Graphic card is faulty try no built-in/intergarted graphic card such as Nvidia or sis that u computer would support.
Posted on Mar 14, 2009
SOURCE: my dell optiplex 360 model pc have built in
The optiplex 360 does come with internal speakers(it's in the spec sheet as optional), we bought them for our entire IT department and they worked fine on XP and vista, but when we put 7 on them, we can't get the internal speaker to work.
Posted on Dec 09, 2009
Hyundai U220WD LCD monitor displays OFF MODE (on a black backgroung). How do I restore the display? What does the MWE button do?
Hi
If the screen is connected to a computer usually its a video card/ video cable problem and not the LCD monitor. Try to check the video cable look for loose connection or bent pins, if none try using a different video cable or checked the video card component of the computer too see if its still working,. Your monitor is dependent to your video card signal inside the computer. Without the signal monitor will not work.
thanks for using Fixya
Mar 25, 2011 | Hyundai Electronics N220W 22 inch LCD...
Won't work - light is on, but won't work.
you are having some kind of video adapter problem either you are using either a video card that has possibly failed or you are trying to use a video card that the card was installed before the driver was installed and your motherboard is still sending the vid3eo signal to the built in video adapter. it could also be something as simple as a bad cable from the pc to the monitor.
Sep 13, 2010 | Computers & Internet
My monitor does not bring the bios set up and up saying no input signal what are the solution and causes
Check that the "data" cable is tightly-connected at both ends (monitor & video-card).
Try connecting the monitor to a different desktop/laptop computer, to see if the monitor works at all.
Try a different "data" cable between the monitor and the video-card;
obviously, your monitor's "power" cord is working, and thus, there's no need to swap that cable.
Try connecting a different monitor to your computer, to see if your video-card is transmitting any signals.
Temporarily swap-in a different video-card, to see if the video-card is the problem.
If all else fails, take the computer to a technician at a computer-store.
Aug 16, 2010 | HP w1907 LCD Monitor
I turn my Gateway E4100 on and all the lights come on and the fan comes on but the monitor will not display anything I have tried a few different monitors and the ame thing always happens. Any thoughts?
Default Video Adapter Might Be Set Wrong Within Bios, RESET Your CMOS, by taking the pin and taking it from 1-2 and put it on 2-3. Or Just Take Out The Battery On The Board. Change Ur Adapter To Whichever Matches Your Card. PCI, AGP, PEG (PCI-E)
I Also Assumed Your Video Card Wasnt Built On, You Could Try Plugging Your Monitor Into Your Build On Video Adapter.
If All Fails, Try A Different Video Card. I Had a video card kill my computer once
Mar 16, 2010 | Gateway E-4100-Pro Deluxe (E4100P-D) PC...
My 2 year old out of the box Gateway GT5220 boots up as usual but there is no video signal from the onboard video card. No modifications to this unit at all.
After verifying this issue with a second monitor, it would seem a new video card would be in order. As far as I cant tell this model has built in video, often referred to as integrated. therefore replacing the current video component will not work. You will need to install a PCI-E video card. Often referred to as PCI express. This computer has one slot available for a PCI-E card. If that doesnt solve the issue then the problem extends past simply the video signal.
Nov 13, 2009 | Gateway GT5220 PC Desktop
No signal keeps appearing
This message means the monitor is not getting a video signal from the computer.
This could be a loose video cable, a faulty video cable or a faulty video card.
It is possible the monitor is faulty, try connecting it to another computer with a different video cable. This will tell you if the monitor is faulty or not.
Sep 14, 2009 | Acer 22" X223w LCD Monitor
In-built video card not working. how do i switch if off and use another video card via PCI slot?
you can disable from bios
is likely onboard vga
But if you plug in a PCI video card the computer will use that video card
Jul 09, 2009 | Intel Motherboard
My monitor displays no signal, i tried to tighten a display cable but the problem persit, i put my monitor to another pc it works fine, later i decided to remove the ram and see if the computer will alert...
Hi! In your case, if you already check all the connections, the problem is in the display card adapter pls check your VIDEO card if its properly inserted, if it does. Then you have a defective video card. GOOD LUCK thanks
May 15, 2009 | Microsoft Windows XP Professional
Not booting up no video
try reinstalling it from your device manager and the wizard program will guide you and make sure you have the disc for the driver youll need it.. thank you for using fixya have a nice day,..
Dec 11, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
