Question about Kitchen Appliances - Others
How to replace the battery on a bbq electronic ignition
Where is the battery
  • 3,961 Answers
Most of them don't have a battery at all. They operate by piezo-electric ignition. When you operate it, a spring strikes a crystal with a little hammer, and this causes a discharge of voltage and a spark. If it has ceased to work, there is an adjustment you can do
https://www.youtube.com/watch?v=c_sEDsyOCzE
or replace it cheaply
http://www.theartofdoingstuff.com/karen-answers-how-to-replace-a-busted-bbq-ignitor/
Posted on Mar 22, 2014
Where is the battery located on this grill?
No battery. The igniters are piezo style that doesn't use batteries. If it has failed, you can get a replacement at any store that sells BBQ grilles or home improvement stores.
May 04, 2017 | Grilling
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Jan 01, 2014 | Weber Genesis Gold B Grill
Replaced battery and unit still does not ignite
not enough information. is battery installed correct? are all the module spades attached or grounded? is gas flowing so the bbq can ignite with a manual lighter? are the electrodes coated with grease so they will not spark? Are the electrodes 1/8-1/4 inch at the tip so they are able to arc?
Oct 18, 2013 | Weber Grilling
I need a new thermostat for my BBQ, where can i get one
Try Calary bbq center the are on line , they could well help you.
May 20, 2011 | Heavy Duty BBQ Parts Igniter Wire...
Cant get bbq to light
Make sure the battery is in correctly, then check the wires from the ingniter to the electrodes, if they are connected and ok, then check to see if there is a spark from the tip of the electrode to the collector box or burner. If there is no spark, then it could be the igniter, electrode or wire. Hard to tell with out trouble shooting.
Jul 06, 2010 | Grilling
Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
Ignitor on gas BBQ no longer works. Replaced battery and cleaned out chamber (light rust). I've tried to remove the ingnition housing, but the entire front panel of the BBQ needs to be removed. Suggestions...
Check to see if the probe where it sparks to the burner inside the grill is clean and not shorted by grease or other gunk and the burner itself in this area is not too heavily rusted or corroded. If not, short of disassembling the whole grill and replacing the spark module, spend $2-3 and buy one of those pistol type grill lighters. The ignition systems on BBQ grills rarely seem to last long.
Feb 24, 2010 | Grilling
Wehave a eurolec 3572 9 506 cooker,fan forced oven,4 burner,griller & bbq plate. The electronic ignition has stopped working, is it a battery we need to fix this or is a repairman required?
I'm Neil
No problem
Sounds Electronic
There may be an electronic problem !
Call service!
Thank You for asking!
Neil
Please rate my solution
Aug 24, 2008 | Kitchen Ranges
Kitchen Appliances - Others Logo
49 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
