Question about Olevia LT37HVS 37 in. LCD HDTV
Image is burnt into screen
How can i get a burnt image out of the screen?
Computer comes on but not the screen.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Gateway MX6453 Notebook
HP Pavilion dv1000 Notebook PC display not coming on
Does the laptop power up even though you can't see an image on the screen?
Connect an external monitor to your laptop and powe it up, if you see the normal Windows images then the laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 22, 2009 | HP Pavilion dv6000t Notebook
Full screen on my laptop only shows black screen but i still hear the sound how can i fix this
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 16, 2009 | Acer Aspire 4720 Notebook
Want to replace Averatec 3200 Laptop Screen
Do you know for sure the LCD screen and not the video card is faulty?
You may find it cheaper to repair the LCD screen than replacing it.
Mar 16, 2009 | Averatec 3200 Notebook
"Flickering" screen
Mar 15, 2009 | Toshiba Satellite A105 Notebook
Screen goes blank while typing
Mar 14, 2009 | Acer Aspire 5315 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Mar 13, 2009 | Gateway MX7118 Notebook
Dark unreadable screen
Mar 13, 2009 | HP Pavilion dv6000z Notebook
I can tell the power is on but I get nothing on the screen.
Mar 12, 2009 | Gateway MT3418 Notebook
Image burned into screen
The image you see is burned in the CRT's,nothing wrong with
screens.As you might expect, red,green and blue CRT's are
very expensive,about 400.00 each.
Nov 14, 2006 | Toshiba TZ55V61 55" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
22 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
