Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
I need a replacement motor for my Protocol Manta. Anyone know where to find a motor(s) for them?
Need Replacement Motor
Where do i put the blades
Its actually quite simple if you follow what I say. I am assuming that you removed them all and forget where they go.
Usually, the two front rotors are a lighter colour, but opposite in pitch/rotation.
What you must not forget is that all propellers must only try and pull upwards, that is blow air downwards.
Then power the model without props and make each motor run (or all 4 together without any props. Note on a piece of paper the direction of rotation of each motor, mark front at the right place on the paper!
Now look at each light coloured props, they should be opposite handed, imagine them turning in the direction of each front motor and pulling upwards. Put each one on the front motors as you think they should go.
Switch on the copter, link the remote control, hold model firmly and make motors turn. Both motors should blow air downwards. If the opposite, swap them. Test again.
Do the same for the rear motors.
Do not forget that the colours are only to help with finding the front when flying, otherwise the pair of propellers at the front are the same as the ones at the back....so you can place the coloured pair you like for the front or the back, where you wish to have them.
I hope this helps.
By the way, the motors are often sold as four, each one with its own position, but in fact the motors are either turning CW or CCW.
I have not ever tried reversing polarity, as this might possibly damage a motor if they are brushless....so don't try that unless you KNOW its OK.....
Someone here may already know for certain....
regards
Andy
Jul 18, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Manta 4 channel rc quad-copter will not calibrate properly
Sounds like the axle is slightly bent and warped from the initial crash. Try replacing the axle and this should solve your problem.
Apr 19, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Where can I buy a tail rotor motor for my protocol sb 3.5 channel
You can order here. https://www.shopprotocol.com/spareparts/tail-rotor-and-pinion-gear-predator.html
Mar 07, 2014 | Protocol Predator SB 3.5-Channel...
Ridgid TS3660 10 INCH TABLE SAW TH100085 MOTOR. I need replacement part for thermal cutoff switch. I broke the red button off the switch and now the motor will not start. I cannot find a replacement...
I have been fixing table saws, compressors and other tools with similar motors for several years and I have never been able to find anyone who sells just the thermal switch on these motors. I usually use one from another motor that's burned out if I need one. You'll have to find a repair center that has motors they could take one of these switches out of and sell/give to you. Otherwise, it's a new motor to get one.
Jan 30, 2013 | Ridgid TH100085 Motor
IQAir HealthPro Plus; need a replacement fan; anyone sells these other than shipping this back to IQAir
There is no listing for the fan IQ Air uses in its units, but you could pull the fan unit from the case and match it to one of the many fan motors at this site:www.emotorstore.com/
Jan 10, 2013 | IQAir HealthPro Plus Air Purifier
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Dec 31, 2012 | KitchenAid Food Mixers
AC condensor fan motor replacement
one wire goes to the coil one to the capacitor and one line
Jun 20, 2009 | Carrier 38CKC036 Air Conditioner
Too much noise from the motor, can we replace for a quiet one?
Unfortunately I have yet to see a "quite" motor for a jetted tub. The only soultion I have found for the noise is to use rigid or fiberglass insulation on the inside of the tub platform. Care needs to be taken so as to not block the back of the pumps or blower, this will restrict airflow and cause damage to pumps/blowers.
Apr 12, 2009 | Home
Heat blower motor stopped
Hi. And welcome to FixYa. You need to remove the glove box door, and then you can get to the blower motor. 3 screws holds it in. Easy to remove.
A FIxYa rating for my assistance (4 blue diamonds) would realy be appreciated.
Feb 11, 2009 | 1996 Toyota Corolla
Thorens Motor Replacement
All motors generally work the same, and 95% of them have the same power requirements. However, the only issue you might have is in the actual size of the new motor. If you can get it to fit where the old one sat, then your ok. If not, well, then it wont fit.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 19, 2008 | Thorens Audio Players & Recorders
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
98 people viewed this question
Top Protocol Toys Experts
 Mikey
Mikey
gmduvall
 Russ Hill
Russ Hill
Are you a Protocol Toy Expert? Answer questions, earn points and help others
