Question about Fujitsu Siemens Computers & Internet
Keyboard unlock fn key lock
When i press k,i,.. monitor showing 2,5... how can i deactivated
  • 239 Answers
SOURCE: keyboard Fn key
Try hooking up and external key board see if that works ok, and if it does you may want to try to find a new or used key board for your laptop. The key board may be shot, It should be fairly easy to change to a new board, Hopefully That will help you diag. the problem..
Posted on Jan 06, 2008
Nitrotrike
  • 589 Answers
SOURCE: Panasonic Toughbook CF-51 laptop blue FN key locked on
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
Posted on Jan 09, 2008
iqbal_del
  • 655 Answers
SOURCE: keyboard problem
Do the following steps:
  1. Press and Hold Fn then Press Numlock/Scroll lock, if it works then good.
  2. otherwise Press and Hold Shift Key then Press Numlock/Scroll lock.
If still problem just Ask me
Thanks
Iqbal
Posted on Apr 13, 2008
  • 334 Answers
SOURCE: Fn key problem with Gateway notebook
Hey there, this is an easy fix, just press the num lock key:) let me know if for some reason that doesn't work
seth
Posted on Jun 26, 2009
  • 3 Answers
SOURCE: It seems like fn key stuck because everything,
Try holding fn key and hitting scroll lock or num lock to see if that does it. sounds like you have somehow locked your fn key on.
Posted on Dec 14, 2009
Monitor not working when plugged into laptop
On some laptops, you need to enable the external monitor port. Look at the number keys across the top of the keyboard. There should be some legends in blue on them. These are associated with the Function (Fn) key. One of the blue legends will most likely activate/deactivate the external monitor port. Press the Fn key along with the associated number key to activate/deactivate the monitor port.
Sep 06, 2014 | Envision Computers & Internet
Locked keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
On most laptops there is a function key that will lock the keyboard.
You would need to pres the [Fn] key and the appropriate [F#] key. In mine the combination
would be [Fn+F1] keys. If you shut down to re-activate the keyboard you will loose whatever you are working on.
hope this helps
Nov 10, 2012 | Computers & Internet
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Nov 08, 2012 | Computers & Internet
L had formatted my dell insporon and now fn key is not working....is there any driver for that tooo???
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Oct 09, 2012 | Computers & Internet
In my key board m button tyed show 0 why
You probably have Number-lock active, test and see; u = 4, i = 5, o = 6, j = 1, k = 2 and l = 3.
On the bottom left of your keyboard you should find a key marked Fn. On the top right of your keyboard you should find a key marked Num LK. While pressing the Fn key, press the Num LK key once. this should unlock the number keys and allow you to type letters again.
Good luck ;)
Feb 02, 2011 | Computers & Internet
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Fn key won't unlock
On Dell to activate press
<Fn> + <Num lock>
to deactivate press
<Fn> + <Num lock>
On most laptops you deactivate Fn pressing:
<Num lock>
or
<Fn> + <Num lock>
or try
<Strg> + <Shift> + <Num lock>
I hope it is working for you.
Aug 27, 2009 | Dell Inspiron 1501 Notebook
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Locked keyboard buttons
You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
Press the Fn key and that key and your keyboard will return to normal.
Apr 20, 2009 | HP DC170B Keyboard
Computers & Internet Logo
106 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
