Question about Logitech Audio Players & Recorders
Logitech z623 sample rate bit depth
4 Suggested Answers
SOURCE: Sample rate switch issue
pci\ven_1039
Posted on Apr 15, 2008
  • 3 Answers
SOURCE: scanning monochrome negatives on Coolscan 5000ED
Your killing yourself how big are you going to print this!!! Are you using Vuescan or silverfast for scanning or Nikons util? Stay away from Nikons utility! 2x sample is plenty and turn off ICE for monochrome (it makes a mess of things) but 16 bit yes until you print then go down to 8 after you resize for final print.
Morphoto.ca
Posted on Nov 14, 2008
  • 382 Answers
SOURCE: Pls tell me what range
One possible cause would be the player. Their is a chance that the DVD player do not support the version of your AVI. Try to use Total Video Converter, this is what i use when i cannot play a video on our LCD TV. Hope it helps thanks.
Posted on Sep 21, 2011
I am recording voice over work in my home studio. I am using a behringer mixer "new" with usb interface, a new NT-1 Rode mic, into a lap top with audacity installed. I am getting clicks, tall single
Sounds like a clock or bit depth issue. Verify what sampling rate and bit depth is coming from the USB interface, and make sure the laptop/Audacity is set for the same.
Oct 27, 2014 | Audio Players & Recorders
I plugged my Logitech Z623 (110V) into a 220V output. Made a 'pop' noise and now it doesn't work. What parts need replacing and how would I do this?
Take unit apart an look at power supply. It could be just the solid state fuse popped. Power supplys are not hared to repair, the diodes are about .50 a piece, the caps about $1 a piece or so. Hopefully ot did not reach the speaker, an i doubt it did.
Oct 12, 2014 | Logitech Z623
Logitech z623 110v burned to 220v what parts need change i need help
You have a direct short in the power board. Replace the speakers.
Mar 26, 2014 | Logitech Z623
Why is there no bass from my speakers when plugged into laptop?
Could be something wrong with the output from laptop.Try wiggling the jack in the connector while music is playing to see if there's any change.
May 21, 2012 | Logitech Speaker System Z623
I have just bought Logitech Z623 Speakers and connected with my computer. All Speakers work fine upto certain Volume and Bass level but One of the satellite Speaker ( Mostly Speaker with Volume/Bass...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
other than that you might have a warranty issue
hope this helps
Aug 08, 2011 | Logitech Z623
Music files such as mp3 wma etc etc work , but the ones with a bit rate of 64 do not. Is This normal or can it be resolved??
hie dear,
the standard mp3 song is:
bit rate = 128kbps
channels = stereo
audio sample rate = 44100 khz
reducing bit or sample rate means compressing the song, although it can be played on max of handsets.
bt u can use the mp3 converter softwares to increase or reduce the bit or sample rate to make the bit/ sample rate standard.
bunty
May 11, 2009 | Nokia 6300 Cellular Phone
Krackling sound with logitech clearchat wireless at 44khz
Bandwidth sounds logical, so check if your USB ports are configured as USB 2.0 and not USB 1.1 (which is slower).
Apart from that, it could really be a driver compatibility issue. The driver architecture in Vista is different from XP, so even if the driver is accepted, it does not mean it provides the same performance and quality. Best if you can get real Vista (signed) drivers.
Jules
Mar 21, 2009 | Logitech ClearChat Stereo Headset Headset
Playback is to fast
Oh wow dude,
it sounds like your bit rate and sample rate are out of whack. You should shoot an email to tech support cuz this is gonna need some more in-depth help than i can really get into here. But check your bit depth and sample rate first. They may be out of sync
Jan 27, 2009 | Cakewalk Music Creator 4
Scanning monochrome negatives on Coolscan 5000ED
Morphoto.ca
Mar 05, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
94 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
