Was driving herd a ticking nopise then a clunk noise then stopped restarted it then stopped and now wont start just makes a wooo noise like slow to start but wont start its a 96 model
SOURCE: 1997 mitsubishi eclipse,GS Spyder, front passenger wheel
CV AXLES NEED TO BE REPLACED. LOOK AT THE RUBBER BOOTS ON THE INSIDE OF THE WHEELS WHERE THEY GO INTO THE TRANSMISSION AND YOU MAY SEE GREASE. I HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR USING FIX-YA.
SOURCE: 2001 mitsubishi eclipse 3.0l ticking noise
No. The valves are hydraulic. Pour about a coke tin amount of diesl in with the engine oil. Run the enginr to normal teperature. Drain the oil and refill with new oil. It sounds like a lazy or blocked follower. Once you do this it should disappear.
SOURCE: first start car ticking noise after 5 minutes it
This is the tappets on the top of the engine ticking cause they havent got any oil yet. When you first start it take a few secs to get the oil to the top of the engine...It is a warning of impending trouble, but it may or may not be quite a ways off...
SOURCE: 97/Mitsubishi Nimbus with engine ticking noise
If the noise is from the top off the engine it is most likely a failed or failing lifter.
Tom
SOURCE: Engine ticks when first start up and the stop
ok the ticking noise is your lifters and you try and use a thicker weight oil in it it should go away
