My toshiba 57h81 has a distorted picture when on the main screen. but when on pop the left screen is distorted but the right is not
Thats all i know to tell you
  • 87 Answers
SOURCE: Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Posted on Nov 25, 2007
BMW Rider
  • 232 Answers
SOURCE: toshiba 46wh08b projector television
Doug, convergence circuit is failing, involves removing one of the boards, replacing the convergence IC`s and probably a couple of burnt resistors, not a "layperson repair", requires soldering experience, accurate voltmeter to find the bad resistors, etc. I would suggest calling a tv tech for this repair, questions? e-mail me back BMW Rider
Posted on Jan 09, 2008
  • 59 Answers
SOURCE: Distorted Picture
the hyper module is defective needs to be repaired or replaced.
Posted on Aug 03, 2008
Sparko1
  • 167 Answers
SOURCE: Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
Posted on Jul 29, 2009
Ecollier2012
  • 3459 Answers
SOURCE: fuzzy/ distorted tv pic
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
Got used Toshiba 57H81 and picture is fuzzy like 3D. Touch focus error message shows.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Toshiba 57H81 57" Rear Projection...
I have two lamps out in my Toshiba 57h81. How do I know what the part number is for the lamps and where can I get them?
Hi, the lamp you talking about ,they are your picture
tube [in projection tv you have tree separate tube 1 red 1 blue 1 green ///if you have one still working
you must have a blue or red or green picture
so you probly have some thing in the electronic circuit ,for your tube heater are defective / and that can be fixed because the
price of these tube are arround 300_ box/each
hope that will help you///verify first the soldering of connector where the wire are connect to the tube to the main board or some resistor blow the heater voltage is 6.3 volt ////good luck ask some one you now he know electronic
Apr 02, 2010 | Toshiba 57H81 57" Rear Projection...
Red color convergence on Toshiba 57H81
Often convergence issues do not require the entire board to be replaced. You can resolve it by replacing the convergence ICs. The part in question is STK392-110. You will need two of them and they cost around 10$ each. But replacing them is a pretty complicated procedure and I would not suggest it to someone without prior experience. A service manual should get you started in the right direction if you are planning to do this yourself.
https://www.completeservicemanuals.com/toshiba/crt-projection-television/57h81-service-manual/prod_1128.html
PS
: Disconnect from the power supply before you start the repair. Also read the legend, the hv circuits are denoted by a special symbol, so you will know what you shouldn't touch.
You may also need to replace the nearby resistors that may have popped the IC in the first place. Read the service manual for further details.
Good luck,
Sai.
Apr 01, 2009 | Toshiba 57H81 57" Rear Projection...
57H81 projection tv has very wiggly picture.
This is the Hyper Module that needs repaired. There are several small sm caps that dry out in this model. It's the module standing up to the right covered by a can as we call it. I really don.t recommend you trying to repair it. One slip and that module is done and you can't by a new or rebuilt one anymore. Please let a repair center look at it and do the work. You won't regret it.
Mar 08, 2009 | Toshiba 57H81 57" Rear Projection...
My Toshiba 57H81 has a 'jittery' picture.
I have the same prob need to change the resistors as a first resolution. there should be 5 of them, if you dont soon and i mean soon you could cause the skt to go bad and have to start over in your repair
Fuzzy/ distorted tv pic
*Screen Looks 3-D
*Colors wont align
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Distorted Picture
Aug 03, 2008 | Televison & Video
Toshiba 57H81
check closed captioning settings in the menu
Mar 31, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81 Color Problem
sounds like your green tube is set to high.
take the front cover off and the plastic cover under that
you will see a black box about 6x6 with 6 controls one is for focus the other is for intensity
here a guide for sony but yours should be close.
Mar 14, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 57H81Problems Please Help
On this model I've found the hyper module to cause lines (Left to right) in the picture. Usually at start up and half the screen, then after warm up, the set will clear up some or completely. Of course a picture of the problem would help in diagnostics. The hyper module must be soldered in, so, knowledge of soldering is advised. This PCB can be bought at: Andrews Electroncis or Tritronics. I do this job in the home, pick up for service should not be required.
Jan 06, 2007 | Toshiba 57H81 57" Rear Projection...
k24674
jasbo
jasbo
