Question about Acer Computers & Internet
Monitor computer blink monitor
Menu keep on blinking
Disconnect the monitor from the computer. Then turn on the monitor, if the menu keeps on blinking then that means the screen is starting to go bad and the monitor needs to be replaced.
You can also hook up the monitor to another computer. If the blinking stops then that means its an issue with the video card in your original computer.
Feb 05, 2012 | Samsung Computers & Internet
Monitor blinking but will not come on
most of the time the blinking is a form of error message from the monitor depending on how many blinks in between each pause lets service technicians know which breaker fuse or transistor needs to be replaced
I would suggest taking it into a computer repair store and have them attempt to fix it however alot of the times its cheaper to just buy a new one
Hope this helps
Robb
Apr 26, 2010 | Dell E193FP 19" LCD Monitor
When i turn on the monitor, the screen will not stay on...it continuously blinks and blinks and blinks. I tried turning the monitor on and off but it does not work. Any solutions??
monitor could be going bad. plug in the same computer and cable to another monitor. see what you get. same problem? use a new cable on either/both monitors see what happens. this will help you determine if the problem is in the monitor, cable or computer's video output.
Aug 30, 2009 | Computers & Internet
After hibernate mode monitor blinks on and off. The monitor is on power is being feed to monitor however if you turn the power button on and then off the picture on the screen will blink on and then off
If it is your computer that is in hibernation then blinking on the monitor light is normal
Just bring your computer out of hibernation and the screen will come back to life too
Aug 22, 2009 | Dell Computers & Internet
No picture - power button is blinking green
The "blink" is an indication that the monitor is *NOT* getting any signal from your computer's video-card. Either your video-card is the problem, or your computer is "sleeping", and you cannot "wake" it.
Reboot your computer, and watch the monitor, to see if anything at all is displayed.
Reboot with a different monitor connected, to see if anything at all is displayed.
If another monitor works, your monitor is the problem. If neither monitor works, it's the vide-card inside your computer that is the problem.
Aug 13, 2009 | Computers & Internet
Monitor Blinking
HI SrFixer -
Since you were able to attach another monitor to the computer and it worked, that would indicate that the problem is not a computer problem but a problem with either the monitor or the monitor cable (data). Try another monitor cable on the monitor that didn't work and see if that works. If it still does not work, then I am afraid that your monitor has gone bad and needs replacing.
Hope that helps
Michael
Nov 28, 2008 | Computers & Internet
The monitor gree light blinks
It may be your power cord to the monitor. Did you use the same cord when you attached the monitor to a different computer?
May 17, 2008 | ViewSonic VX924 19" LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
