Hello. I'm a little confused at the description of the problem. You indicated it, "will not agitate during wash cycle or spin during the spin cycle." But later in your description you indicated, "It will however, drain and spin after wash cycle and during the rinse cycle." I'm not sure if you description was an error but it sounds like you will need to replace the coupling which is part number 285753A.
If your Maytag washing machine is agitating during the spin cycle, it could be due to a few different issues. Here are some possible causes:
Defective Transmission: The transmission in the washing machine is responsible for shifting the agitator and the drum between the spin and agitation cycles. If the transmission is defective, it may not be able to engage or disengage the agitator properly, causing it to spin during the spin cycle.
Worn Drive Belt: The drive belt connects the motor to the transmission and helps to control the speed and direction of the agitator and drum. If the belt is worn or damaged, it may not be able to properly control the agitator, causing it to spin during the spin cycle.
Malfunctioning Clutch: The clutch in the washing machine helps to regulate the spin and agitation cycles. If the clutch is not functioning properly, it may not be able to disengage the agitator during the spin cycle, causing it to spin along with the drum.
Faulty Timer: The timer controls the various cycles and functions of the washing machine, including the spin and agitation cycles. If the timer is faulty, it may not be able to properly sequence the cycles, causing the agitator to spin during the spin cycle.
It's best to have a professional technician inspect and diagnose the issue to determine the exact cause and the necessary repairs.
Transmission is bad. The transmission is not used during a spin but it is used during agitation. Check your warranty, the transmission maybe covered for 10 years for parts only and 5 years for parts and labor
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
