Question about Samsung Galaxy Cell Phones
Short circuit no power nothing, i check the board with meter its showing 25 percent short circuit of galaxy s3. give me the solution
SOURCE: Windsor Sensor 12 Vacuum No Power
I'm an engineer for Hyatt hotels and I've worked with the S12 vacuums for a few years now. The most common problem electrically lies in the main switch and the power cord. Almost at no time in the past three years and working for 4 hotels have I had to replace any motor or board component for them. Take out the handle from the bag housing and use your volt meter/circuit tester to test the main switch, if that and your power cord are good, then you might have a bad fuse, which is located on the brush side of the main chip board. Any other questions, feel free to email me directly @ andrew.massey@gmail.com
Posted on Feb 29, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Coffee maker: no
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
SOURCE: Maxent 26" lcd tv, shorted circuit board
the best and easiest way to track down a short is with a digital multimeter just check for continuity throughout the circuits.If you you cannot get your hands on a multimeter use a compass.It will detect and move left to right when there is a complete circuit and as soon as you hit the short the needle will be dead still. Fix the short and test.It would probably be alot cheaper than trying to track down a part with no certainty of it.Hope this helps
Posted on Mar 18, 2009
cadman000
  • 607 Answers
SOURCE: Service engine soon light comes on, checked with a meter and it is showing evaporative purge control valve circuit, what is it talking about
The EVAPORATIVE PURGE CONTROL VALVE is located under the hood usually behind or near the back of the headlights. It it on the top of the Evap Charcol Cannister ( shaped something like a Quaker Oats box ) . Basically does not allow fuel vapors to escape into the air. Te purge valve will recycle the vapors through a charcol filter and sent to be reused as fuel., Problem could be caused by excessive fuel in the cannister, or the solenoid, or wiring, etc back to the computer.. Requires a lot of diagnosing. Hope this helps.
Posted on Apr 13, 2009
  • 181 Answers
SOURCE: Galaxy 949 Receive problem
this sounds as the osolator has moved of freq. to check this you need to put it on a scope
Posted on May 22, 2009
Powering problem
Check plug first the one you plug in wall if there is a small black box at point were you plug in ,there is a transformer in there sometimes they short out .Check with multi meter if it is good then try schematic or Circuit diagram
Feb 07, 2016 | Roland Boss ME-25 Guitar Multiple Effects...
Keyboard won't let type and then disappears
I can't type on my device. Keyboard won't show ... ' T-Mobile Support
https://support.t-mobile.com/thread/48985?start=0...
T?Mobile US, Inc.Aug 11, 2013 - Please let us know because we want to make sure it's working for you. ... After opening the app I pressed "Force Stop" and then cleared the data. ... phone butthen i cant coz i cant type my password that is needed to reset it.
My Galaxy S3 won't let me enter text? - Android Forums at ...
forums.androidcentral.com > ... > Samsung Galaxy S3
Mar 10, 2013 - 25 posts - ‎15 authors
The keyboard comes up and does one of two thing: 1. it lets me type, suggests a word that I select & then doesn't place it into the text area OR it doesn't let me type .... Each character just kept disappearing as I typed the next. LG Keyboard has stopped
Jul 23, 2014
Samsung Galaxy S4 Keyboard can't remember added ...
Feb 21, 2014
keyboard disappearing while typing??
Jul 16, 2012
Digital Keyboard won't appear; ICS
Jul 15, 2012
More results from forums.androidcentral.com
HTC's Sense UI is Garbage: A Tale of D
Jan 01, 2016 | Tablets & eReaders
My samsung S3 mobile is frees and not turn on kindly give me solution
this will wipe your phone and any glitches that may be associated with it:::sgs3 hard reset or reset Galaxy S3: PRESS AND HOLD VOLUME UP + Home Button + Power
Turn the phone off
Press and hold Volume UP and Home (center) button
Press Power until the phone vibrates
Wait until you see the Android logo then release all the buttons
Select Wipe data/Factory reset with VOLUME DOWN, press Power (right hand-side)
Select YES...delete all user data with VOLUME DOWN and then Press Power
After format, press Power again to reboot the phone (select reboot system now)
Feb 26, 2015 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
What are the significant differences of the
Significant Differences between the:
Samsung Galaxy S3 and the S3 Mini:
1. The S3 has all the bells and whistles of being more advanced in hardware and software then the S3 Mini
2. The S3 can last longer in battery life than the S3 Mini
3. The S3 has more storage space available for more apps than the S3 Mini.
4. The S3 is more complex with its many software options than the S3 Mini
The S3 Mini is for the Minimalist who doesn't want all of that, but just cares about having a basic phone with a touch screen that has the flexibility of Android.
The S3 is for the person who plans to use their phone for a multitude of things.. or the person who likes to download a lot of apps, either for gaming, as entertainment for their kids, someone who plans to take a lot of photos, and use it for work. You can do this with the S3 Mini as well, but because of its limitations in speed, on board storage, and battery life.. it won't be able to handle as much as the S3 will be able to do.
Oct 02, 2014 | Cell Phones
My phone is locked. My phone is Samsung galaxy s3
Hi. Do you want to unlock your Samsung Galaxy S3? If so, from what kind of lock do you want to unlock it? If you Samsung Galaxy S3 has been locked up with a network lock, you can unlock it safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from SimpleUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
Jul 12, 2014 | Samsung GT-i9300 Galaxy S3 Unlocked GSM...
Galaxy dx-44v wont power on
check near the rear of the radio.. around the power input connection and the audio transformer there should be a 1n4001 diode.. check it for a short. replace it if it is.. and it should power up.. also in the same area check for any shorted traces.. on the circuit side.. also
on the sides of rci main board radios near the bracket screws theres a transistor voltage regulator.. make sure its connected to the board.. sometimes they come loose.
May 03, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
How do i get the unlock code for samsung s3
You can Contact your network provider and request an unlock code
Insert your new SIM card
Power your Samsung phone on then enter Unlock code.
For more details you can check at Samsung India site.
Samsung Galaxy S3 Price India Buy 3 Smartphone Features Reviews Specs
Oct 14, 2012 | Samsung Galaxy S 4G Cell Phone
I am trying to unlock my samsung galaxy s3 i9300
Hi, You can unlock your Samsung Galaxy S3 safer and easier using unlock code. You can get the unlock code from http://www.wickedunlock.com/samsung-galaxy-s3/rs11wp9/ at affordable cost with easy unlocking instructions.
Sep 19, 2012 | Samsung GT- I9300 16GB Galaxy S III...
Philips 42PFL3704D/F7 TV caught in power surge
Yes usually replacing the power board will solve the issue . You can get the power boards for most phillips at www.tvcircuitboards.com boards all have 6 month warranties
Feb 17, 2012 | Philips Televison & Video
Cell Phones Logo
15 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
