Question about Canon iR2270
The right lower door for canon ir 2270 indictes open as i start the device, beside im very sure thats its clean inside .
The device is clean inside coz i had used the blower to ensure its so.
Cogz
  • 1326 Answers
SOURCE: Canon IR 210S "Close the Lower Right Door" warning
Yes there is a sensor that most likely got knocked out of place. What you can do is to turn the copier off and disconnect the bottom 2 trays from the main body of the copier and turn it back on and just use the top 2 trays. You can change the trays lay out to what ever size you want, but make sure you change the BLUE DIAL to the correct size you want to use. I belive the sensor is toward the front of the copier right by the edge of the door, it may be knocked out of place or the flag on the door is broken off or one of the door pins are broken and the door is not closing correctly.... Good Luck..
Posted on Nov 07, 2008
  • 135 Answers
SOURCE: need cd and user manual for canon Ir 2270 copier/printer
the cd is not needed goto canon and download driver for printing. as for manuals if you dont have them only an authorized tech can get the actual manuals do to canon putting them on the tech site. but you can find websites that will charge you and you can get a manual
Posted on Apr 19, 2009
canontech
  • 1219 Answers
SOURCE: Canon IR 2270 The copier print
these means that copier cant detect the toner in developing/toner assy.
You should try to reconnect the toner developing assy and try to vacume it.
Also check if the toner bottle is rotating, if yes that means that toner is being dosed and problem is developing assy.
If you do not want to call service write me on emma.servis@gmail.com for service manual.
hope that helps!
Posted on Aug 23, 2010
Testimonial: "very helpful i just remove check and reconnect the toner cartrige and the issue is solve "
Elbastardo
  • 21 Answers
SOURCE: The canon ppc( model. ir 2270) fonund the problem
The platen glass had been reversed when being cleaned by the technician. Make sure the platen glass has the red arrow in the rear left corner of the machine top plate.
Posted on Sep 14, 2010
SOURCE: We have a Canon iR
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
Posted on May 04, 2011
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Canon ir2870 e000732-0010
your problem might be faulty connection on your DIMM modules.
Take it out and clean the contact area with a brush, place it back and start the machine.
If this dose not solve your problem it means the Reader Controller PCB is faulty and needs replaced.
Oct 29, 2012 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Can not get the copier to pull paper from the top draw with out jamming each time.
first, pull out the top drawer and open the right lower cover and door. now if you look into the "hole" where was drawer, on right side you will see the 3 rollers that pick, feed and separates the paper.
Remove all rollers and clean them with alcohol and dry them out, or change the places with rollers from lower drawer. Also when the right door are opened you will se two axis with two rubber rollers, clean them very well.
The iR2270 has issues with pressure on lower right cover and you need to put the rubber or similar in wide and narrow slot on lower cover, so that when its closed presses the inner paper guide which touches the rollers on axis. If You already have metal "wings" on lower cover, you don't need to apply any additional pressure.
But necessarily change the roller for paper of both cassete's and in fixing unit the fixing cleaning roller.
Hope that helps!
Mar 22, 2011 | Canon imageRUNNER 2270 Copier
Nov 06, 2008 | Canon imageRUNNER 210S Copier
Removing transfer belt
The Intermediate Transfer Belt (ITB) slides out from the right hand side. Open the manual feeder, pull out the right side transport, remove one screw and remove the cover behind the manual feed door, lift the sensor bracket above the transfer belt,lower the handle inside the front cover and pull the ITB straight out the right hand side.
May 24, 2008 | Canon imageRUNNER C3200 Copier
Canon iR2270 Logo
49 people viewed this question
old marine
old marine
