Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Loud noise while running
Smells burning
    New Friend:
Hello. Did you get an answer to this inquiry. Mine is doing the same thing. Smell of burning plastic; continues to fill and drain at the same time?!! I have to manually shut of water to stop the water and then manually set to spin so it will drain!
Posted on May 15, 2014
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Loud Screeching
Check the drive belts or serpentine if there is only one. sounds like one is slipping.
Dec 11, 2013 | Mitsubishi Cars & Trucks
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
When I turn on my 2001 elantra air conditioning, it makes loud noises and it smells like somethings burning.
sounds like the a/c compressor maybe no good causing the noise and if the a/c clutch is not working right then this can be the smell.
Mar 18, 2011 | Hyundai Elantra Cars & Trucks
Loud sqeeling noises when running. Sounded like a belt slipping. Dryer died all together and smells of burning rubber. Suspect a loose or broken belt. How do I change it?? --Dave
Check and see if the belt slipped off the motor pulley broke or wrapped around motor pulley. Check the idler pulley (large white wheel end of motor) Loose?
Oct 16, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Kirby G4 running very loud and smells hot.
were you put the belt on see if any thing is rubbing against shaft.it may have been the belt,replace the belt and clean out the bab and also the floor brush.
Jul 31, 2010 | Kirby G4 Bagged Upright Vacuum
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
The engine is making a really loud knocking noise and the oil light is on. it also smells like something is burning or running hot
Doesn't sound good. Check oil level. Also check for metal in the oil once you pull the dipstick. A loud knocking noise is a sign of a blown engine may be you spun a rod in which case you would need engine replacement or rebuild
Oct 23, 2009 | 2001 Dodge Stratus
Power steering went out and making a loud noise when turning.
yes power steering is most likely very low , repair leak , as the fluid is flameable
Feb 27, 2009 | 2000 Jeep Grand Cherokee
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
79 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
