Question about Kenwood KAC-X520 Car Audio Amplifier
The base in my car kept on goin high and low for like 2 weeks and after that it worked good for 2 days and then the amp shuts off it wont come back on anyone can help me please
  • bouziane Jun 14, 2009
    i checked all the wires i even changed them and the amp is an alpine and i tried to plug another amp it didnt work either
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Loose cable, bad amp, who knows what it could be, its time for you to find out if it is a simple problem, check the wiring, fuse, and anytning else that seems pissible
Posted on Jun 14, 2009
Channel A wont work
check to see if the signal to the amp is low pass and check to see if the switch is on high pass.. if all checks out send the amp back .. if u want to repair it email me at steven007_maharaj@hotmail.com and i would tell u how
Jun 14, 2013 | Pioneer GM6500F 760 Watt 4 Channel...
My technics amp SU-G75 keeps shutting off and reads OVERLOAD when played over the volume of -40 to -35. I kept playing around and it works fine when the bass dial is on half, but more bass shuts it off. I...
some amps are made more for low ohm loads (bass) and some are made for high impedence loads (mids/highs) and it seems you are asking too much from your amp.
Mar 05, 2013 | Audio Players & Recorders
Hi! My 1999 Cadillac Deville for about 2 weeks started messaging low refrig-ac-off. Check engine light on!.
When you change your oil is up to you,you set the
months & miles you go. Any car with a reminder
for oil is just a gadget
You were told that your low on a/c refrigerant by the
message
Now the check light related or not has to be addressed,
by checking for codes & diagnosing the effected system
Your a/c system needs repair,not added to, only to leak out
& polute the atmosphere
Nov 14, 2012 | 1999 Cadillac DeVille
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Horn and brake lights
First if brake lights arent working then the shiftlock wont work. Works off of same circuit. I would check fuses for brake lights and also horn. Not exactly sure on the 92's but good chance theres fuse's inside car and also under hood.
Feb 06, 2010 | 1992 Honda Accord
2001 Ford Focus - High beam / low beam problem with headlights
just replace the dimmer switch under the column its wore out on the low beam side
Jan 17, 2010 | 2005 Ford Focus
Subs will not work right.
the subs coils are melted and shorting out so the amp shuts off
Apr 22, 2009 | AudioBahn AW1206T Car Subwoofer
Kenwood ps 150
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage is not dropping too low, you may have a defective speaker or a short in the wiring. Check the resistance of each individual voice coil to make sure all are near the rated impedance.
Dec 01, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC-X520 Car Audio Amplifier Logo
42 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
