Question about PC Desktops
Screen goes blank
I have an hp pavilion n3402 and the screen keeps blanking out. what could this be
  • 327 Answers
Re: screen goes blank
Does it flicker or just go black with the light flashing? Does it go back on again by itself? As of now, I suspect the video card is at fault without further details about the problem. Let me know
Posted on Oct 30, 2007
0 characters
3 Points
Blank screen on hp pavilion s5300z
Either VGA or motherboard issue... What were you doing when this first happened?
Jan 27, 2014 | HP Pavilion Slimline s5300z PC with AMD...
I upgraded the memory on my HP a6700f from 4GB to 6 GB, increased the Power supply from 300 to 700 watts and, also added another burner. When I turn the computer on I get the no signal message and the...
Hi ,
1st , is the memory correct for your HP , can it be upgraded , because if its the wrong memory chip that would cause your screen to be blank , as far as your power supply that should not cause that problem ...........the only way to find out is to reinstall your old memory chips and see if your system works,,,,,,,,,,,,,let me know .......................Roy
Jul 22, 2011 | HP Pavilion a6700f PC Desktop
I have done a factory reset on my HP Pavillion slimline and keep getting blank screen?
Hmmmm... nice detailed desktop!
But u failed to mentin ur MONiTOR?
Wut is it? CRT, LCD, monochrome?
Dec 04, 2010 | HP Pavilion Slimline s3407c Desktop,...
HP Pavilion Elite M9040N will not finish loading windows after green bar just goes to blank screen. tryed to restore to factory spects bot same thing.
possible video drivers are corrupt.Try a reboot and hold f8 key down.
When prompted choose start in safe mode,then reboot again as usual.
Aug 30, 2010 | HP Pavilion M9040N Elite Desktop PC
Hp pavilion desktop keeps crashing with Windows 7 just installed? cant someone help?
if the case is that whenever you turn on the computer it presents to you options on how to turn on your computer, safe mode, safe mode with command prompt, start up windows normally and other options of such.
if you select any and it goes blank, and comes up with a screen showing windows driver error occurred.
try to format the system and reinstall the operating system again.
get back to me to assist you better if that doesnt work
Jan 02, 2010 | HP Pavilion (PN153AAR) PC Desktop
When i shut my laptop the tv i use as my monitor goes blank.
Right click the power icon in the system tray (should look like a little plug with a lightning bolt on it.)  Click on "adjust power properties."  Click on the "advanced" tab, then where it says, "When I close the lid of my portable computer," select "Do Nothing."
Jan 25, 2009 | HP GX612AA Pavilion Media Center M8330F...
Computer loads and goes blank
Buy Another Computer Get 1000000000000000 Dollars From Work
Dec 26, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Blank screen
was it working before
check all your cables and lines make sure a pet didnt get behind there also if you have kids make sure they didnt put liquid into your comp
cause if it was sounds like you got hit by a virus that effects all major compartments of comp
green to yellow is standby mode
May 30, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
PC Desktops Logo
184 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
