Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
18.5 hp 42'' mower model no. 917.274811.Mower will not turn over. Replaced battery, solenoid, fuse is okay. Make a clicking sound when we try to start it.
  • Anonymous Mar 19, 2014
    sillanoid makes a clicking sound when trying to start and want start
  • 61 Answers
Ck the terminals battery, solenoid. are they clean? and tight?
Posted on Sep 06, 2009
20 hp 42" deck will not turn over. Will start if I
there is 2 to 3 safety switches on there and any one of them will stop it from running. there is one in the seat, one on the engagement of the mower deck and one in the clutch pedal. some models also had an in-line fuse.
Jul 14, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Ingnition will not even click. Replaced iginition switch, solenoid and spark plug. Checked seat switch, transmission switch, fuse. Started motor turns when jumped. Battery fully charged. Fresh gas. ...
Hi, is the deck engagement lever off or the pto switched off? If it uses a lever check the switch on the lever. If it uses a pto check the pto switch. Hope this helps, regards Phil.
Jun 24, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower won't start. Makes clicking noise.
Check the battery terminal connections for cleanliness and that they are free of corrosion. If the contact is corroded, this is what the clicking would be from.
The battery could be charged, but if the connection is dirty, the power won't be able to engage the solenoid properly.
Hope this helps.
Jul 24, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Won't start,the battery needle goes (-) when the key is turn to start
Can you hear the Solenoid click when to try to start? If not, I had the same problem it was the Solenoid. Sears insisted it must be the battery even though it was weak but not dead. Replaced the battery but it still would not work. Replaced the Solenoid and did the trick.
May 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftmans 3000dlt ride on mower can't start it up all it does is click click changed the selenoid and starter still click click Ammeter runs to negitive when i try to start it and it's a brand new battery...
The starter itself may be bad. Take the starter off, connect it to the battery on the mower with jumping cables + to + and - to battery and ground other to starter. It should spin as if it was going to start the mower. You may have to try different places on the starter for a good ground. If the starter spins, then it's not the starter, but binding. If it was electrical such as seat switch or blade switch it would still turn over but not start. With the starter clicking, it sounds to me that the solenoid is fine.
Apr 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan Riding Mower won't crank, battery OK.
Forget the safety switches for now.The first thing I would check would be the fuse. It will be located on the battery side of the solenoid. Follow your positive battery cable to the solenoid. There will be a small red wire coming off of that post with an inline fuse. If the fuse is good, check your solenoid. There are two wires plugged into spade terminals at the bottom of the solenoid. Unplug the one that is insulated, the other one is a ground. Hook a test light from that wire to ground. When you turn the key to start (with the brake pedal held down), it should light. If it lights, your solenoid is bad. If not, then you can start looking at switches. Probably will be one of the two. Hope this helps. Dwain
May 20, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
343 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
