Question about Car Amplifiers
Stereo in my 92 legend
How do I remove the stereo in my 92 legend?
Re: stereo in my 92 legend
U have 2 take out da center console ashtrey do that u will see 2 phillip heads and u should b good from there
Posted on Dec 30, 2008
  • 109 Answers
The simplest answer: Go to a Honda or Acura dealership and ask for keys!
Posted on Jun 24, 2008
0 characters
3 Points
I have a audiobahn a2300hct and the block where the wiring hooks up on the outside is melted around where the ground wire goes in. Where can i get parts or an old 1 for sale i can use for parts?
There are several facebook pages. Old school stereo for sale, i was into auto sound in the 80s and 90s, legends of car audio. Otherwise watch for one to come up on ebay.
Aug 26, 2016 | AudioBahn Car Amplifiers
How to remove visonik vcd51 head unit from car dashboard
This usually involves removing the plastic bezel around the stereo. Sometimes these plastic bezels hold some buttons for air conditioning and heat, as well as the hazard lights button. These plastic bezels usually are just snapped in with metal clips on the back of them. You can pry them outward and with a good yank they will pop out. Once you have the plastic bezel around the radio removed, there will be 2-4 screws on the sides, or top and bottom. Once you remove those, the whole radio will pull right out of the dash. Then you have to un-clip the wire harness from the car, and unplug the antenna cable. If you plan on putting a different stereo in the car, KEEP the mounting bracket around the stereo, as well as the "wiring harness" that was used to plug into the vehicle harness. That will save you about $50 in parts to put a new stereo in.
Aug 23, 2016 | Visonik Car Amplifiers
How do I reset my pioneer deh-x6500bt car stereo and produce sound from my rear speakers?
a 'reset' of the entire stereo should be able to be accomplished by disconnecting the battery for several minutes: alternately if you remove the faceplate there should be a reset button you would need a pen to press, however you should be able to find the EQ levels and set the balance and fade I think it is so the rear produces sound, if that is not the case, I would check wiring to make sure nothing is loose. I suppose it could only be a software/firmware problem with the stereo itself however, if you have had this happen before and it was fixed without tinkering with the wiring.
Jul 30, 2014 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
How can you test a model 15762536 cy-bg8013zc amp. there is no sound in car stereo
What i would do is remove the amp and do a bench test. connecting it to a car stereo outside of the car This way you know it works or not without second guessing the wiring. I leave a Car battery on my bench for this.
Dec 26, 2010 | Panasonic Car Amplifiers
My car is a 92 ford falcon when u play bassie music u can only just here it out side the car but when u pop the bot u can realy here it wat can i do to make it louder out side the car
crack the windows and drop the sony bull **** and get your self a nice mono block class d amp 1000 rms should be loud enough btw bild your stereo based on rms power not max power rms is the true power you got so like 2 500 watt rms 12s on a 1000 watt rms amp or just a 1000 watt woofer it will be jsut as loud as the 2 12s
Mar 30, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
How do I install my Pioneer MOSFET 50wx4 Super TunerIII in my '93 Jeep Cherokee?
When you go out and buy a new stereo make sure to buy a wire harness kit and a mounting kit. The back of these packages will tell you if it will work for your vehicle. As long as your son properly removed the old stereo, all you should have to do is plug one end of the wire harness into your stereo, the other end into your car, and you're done, no wiring needed. If he cut the wires you may be better off going to an auto shop of some sort to have it installed.
Jul 04, 2008 | Car Amplifiers
Have a code for stereo but dont know how to reset it
find out the users reset the unit...always go to menu..or consult the qualified man to reset ur unit.TY
Mar 17, 2008 | Nitro BMW-482 Car Audio Amplifier
Car Amplifiers Logo
93 people viewed this question
Top Car Amplifiers Experts
Tygh Duval
Tygh Duval
Pablo Gonzalez
Are you a Car Amplifier Expert? Answer questions, earn points and help others
