Question about Astatic 636L Noise Canceling Microphone Microphone
The mic doesnt work ...it use to but all the sudden it quit doesnt even key up so i can hear it my talk back
  • 247 Answers
First, try another mic on the radio to be sure it's the mic and not the radio causing the problem. If it's the mic, check the wiring circuits for a bad switch or broken wire. Simply...the TX circuit is closed and the RX is open when the key is squeezed. The RX circuit is closed and the TX circuit is open when the key is released. Use a simple ohm meter to check for resistance between the pins on the mic (after removal from the radio of course). Open circuit will read 1, closed circuit should be very close to zero. You'll probably find the TX circuit never closes when the key is squeezed. Could be a broken wire or faulty switch in the handset.
Also check...If the mic "keys up"...you see the meter move normally, but no voice...it's either a faulty mic element (the little round thing you talk into) or the audio circuit of the radio has a defective component which a good CB shop can replace.
Posted on Sep 04, 2009
Beaches wont turn mic
I for 1 don't know. But try to go to www.Turtle Beach.com they can help you out. I have Turtle Beach Ear Force XC1 and my mic I can talk but I can't hear anything but if your mic isn't working properly try using a different controller. If that doesn't help try getting a brand new mic.
Jun 23, 2013 | Turtle Beach Ear Force X42 Headset
Sentry headphones with mic
My mic DOES pick up stuff, we just can't quite figure out where the mic actually is so we can talk into it and actually hear us talking pretty well, we can slightly hear us talking into it in a recording, but it's so low! (we/us being me and my friend)
Jan 28, 2012 | Sentry HO900 Headphones
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My Cobra 29 LTD sometimes does not work even though the lights remain on. In other words I can't talk on it or hear anyone even though it appears to be operational
Your mic or mic jack is faulty. Try a different mic. In cobra 29's and some other variants, when you disconnect the mic, the audio is disabled. It will still receive, and transmit(possibly) but you will hear nothing from the radio.
It could be,
  • Broken wire on the back of the mic jack in the radio.
  • Broken wire in the mic cord.
  • Disconnected wires in the mic for the switch.
  • Dirty mic connection pins.
Most likely the problem is with the mic, and not the radio.
Oct 21, 2009 | Cobra 29 LTD CB Radio
I can hear people i just cant talk to them
A few reasons for not being able to talk through the mic is that if parental settings are set. Parental settings can stop you from talking and, if set right, can stop you from hearing other people, which isn't the problem. It could also be that the mic on the headset is broken. If it is, you will have to buy a new one. Try using someone else's headset. If theirs works, then it confirms that it is only your headset. If it doesn't, it might mean that either your Xbox 360 remote isn't working right for voice, or parental settings are restricting you from that action.
May 01, 2009 | Video Game Consoles & Games
The speaker of my phone is not working at all,it mean i can hear you but you cannot hear me.
Hi my phone had similar prob with nobody able to hear me, the hole for the microphone is very small and can fill with dirt and fluff. To fix it I followed a dissasembly guide found on google and took the phone apart and removed the mic(be careful its very small) cleaned out the hole and fluff of the mic the put it back together and its works fine now. Sorry cant help with the not being able to hear other person. Regards steve
Jul 15, 2008 | Sony Ericsson W850i Cellular Phone
I can hear but i cant talk and it says my mic is not plugged in
may I ask u how long have u had this mic because I had mine for a while and this recently started to happen to me and because of the updates sony has been releasing I believe thats the cause because mine didnt start doing that until update 2.41 was released
Jun 03, 2008 | Logitech (980174) Headset
They can't hear me talking
First make sure it wasn't muted. Second the mic opening is in a weird place, the lower left hand corner...a little hole. Make sure that isn't gunked up or if anything go in there. Third...if it is under warranty take it back where you bought it.
Oct 01, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Mic doesnt work
Totally the same with me.. any soloutions anyone?
Dec 26, 2006 | Sennheiser PC130 Consumer Headset
Astatic 636L Noise Canceling Microphone Microphone Logo
227 people viewed this question
Top Astatic Audio Players & Recorders Experts
Michial Gueffroy
Tony
 steve
steve
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
