Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Problem maytag neptune machine - sign Le-
Why say free advice and then ask for money - why??
  • inderadaya Jun 15, 2009
    i wanted to know upfront how much more or less
    i would be looking for repair so i could decide
    if i need to fix this maytag neptune washer or
    not i kept on getting no quote so my solution to the problem is not solved.
    i am in norwalk, ca 90650 - well i kept on asking
    what i might be looking at the repair cost and
    i kept on getting - we can not quote a price on the phone... i was asking more or less... with the problem which said - (le) on the signal
    i have maytag neptune front load - if i am to spend couple hundred in fixing it i might as well get a new machine which will cost me approx 400 to 599 and solve old problems with this machine
  • LG Master
  • 3,361 Answers
I don't ask for money. What is your problem?
Posted on Jun 14, 2009
  • 2 more comments
  • steve
    steve Jun 15, 2009
    What is wrong with the machine?
    What city are you in?
  • steve
    steve Jun 15, 2009
    Your water level sensor is bad. Could be a loose wire rather than a bad part.
    Estimated repair cost in your area $225.00.
  • steve
    steve Aug 05, 2009
    Why give me a bad rating when I answered your question?
  • steve
    steve Aug 05, 2009
Maytag neptune
We had this problem and found that the Printed Circuit Board will burn out very easily. On ours the light bulb inside the door blew causing the PCB to fail. (no joke)
I was quoted $315 for a new PCB. If you look on the internet you will find that a class action suit resulted in a cash settlement for Neptune owners in Canada.
We also had problems with a Maytag side by side refrigerator. Same thing,
a Printed Curcuit Board blew. Whirlpool now own Maytag, they are no longer reliable. We replaced the Neptune washer and the refrigerator. Look on the internet for comments about different appliances from consumers. Don't
waste money on Neptune repairs, a new machine will cost less in the long
run.
Jan 23, 2012 | Maytag Neptune MAH6700A Front Load Washer
Maytag neptune washing machine. The error code is Lr. I know what that means, but it is 11 years old and am wondering if it is worth it to fix or just replace.
I would say yes, just remember that replacement washing machines are getting really expensive. First, get a couple of quotes on repairing your Maytag washing machine. Ok, what does Lr. mean?
Maybe I could save you some money, that is if you are mechanical inclinded. GB...stewbison.
Sep 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune TL. Usually when you hit start to run a load a little water comes out of the discharge hose. It is not doing that. It runs in the wash cycle for about 8 minutes the it pauses...
If the machine is a FAV6800A or FAV9800A google ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
If the machine is a FAV6800A or FAV9800A you can go into Service Mode and tes the Drain Pump. Then we can start to troubleshoot the issue if the above model is your machine type.
This site is not really geared up for DIY folks.
Jan 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
LE message, will not lock the door - Daewoo front load
Hello there:
This is a fairly common problem with these newer machines Here are the 2 most common fault codes on these machines I have listed below this post.
If the machine is still under warranty i would suggest using it normally they will repair this for free
and some of these have a recall on these machines
so i would contact the appliance center where you got this from and see if you can get it repaired ok?
"LE " persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board. 1E persists in washer display Lid lock failure Replace lid lock switch or control board.
Dec 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune - died with clothes inside and door locked
hi there,
sounds like you may have had a power outage or tripped the breaker on the main electrical panel on your house. can you have a look for me please?
if not it's the main control board that is defective.
can you tell me the full model # & serial # (these will be located on your bill of sale, since you can't open the door).
i will check the warranty info and let you know if the board has warranty.
thanks.
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
LE Code
Sorry I missed the LE code in the book.. Too much fun lastnight I guess.. AT any rate.. The Le fault code is a Motor overload warning.  Unplug it for 2 hours and try the machine again with a test wash.  if it persists you need to get a technician out for it.  Hope this helps :)
May 26, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
95 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
