Question about Cell Phones
The phone set doesn't ring although the CD player and alarms work. The handset is set to high volume. Still does not ring, whether the answering machine is set to answer or not.
    Brigadier General:
  • 3,917 Answers
Is it on manner mode if so sometimes it will on vibrate and not ring. Try pressiong and holding down the * button.
first check the ring tones in the celu, sound? if not, you got a "piezo" problem thats the speaker that sound in your celu and nothing you can do, if yes, then you got a seting problem, refer to the manual of the celu or go to the celu store, they will help you for free, in case of a damage one in the store haves jonks to repair it for cheaps....good luck
and if its a iphone then Possible solutions for this issue:
  • Turn off Bluetooth in Settings
  • Turn off WiFi
  • Turn off 3G
  • Replace your SIM card (requires contacting your provider)
  • Reset the iPhone: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Thanks for contacting Fixya
Posted on Jun 14, 2009
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
Also, can't set the alarm clock on the phone.
Make sure u hv right time set.
Then go to Tools> alarm clock>new alarm> name>enter time for alarm to ring>select alarm alert tone> set volume..
NOTE: Yo handset shld be in 'Loud' ring style not silent
May 28, 2012 | Motorola Mobility RAZR V3x Cellular Phone
Somehow the ringer got turned off. Can't figure
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
I have a new nokia e63 not even a month old. The music player is very dull and can hardly hear the sound and is on maximum volume, yet the ringing tone is loud. What is the problem?
Actually these are Professional series handsets in these handsets usually audio volume low compared to other handsets Try these... *Go to Media>Equaliser>Select Set 1>Set all the bars to high
*Go to Music player>Options>Equaliser>Select Set 1>Set all the bars to high
Thank you
Don't Forget To Rate
Jan 21, 2011 | Nokia E63 Cell Phone
KX TGA244B How do I get the ringer back on
Handset ringer volume
4 levels (high/medium/low/off) are
available. The default setting is HIGH.
1 Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Ringer volume” by pressing
4 Press {V} or {^} repeatedly to select
the desired volume.
LTo turn the ringer off, press {V}
repeatedly until “Off ?” is displayed.
5 Press {Save}.
Note:
LWhen the ringer volume is set to off, the
handset will display “Ringer off”, and
will not ring for outside calls. The
handset will ring at the low level when
paged by the base unit.
Jan 05, 2010 | Lands Phones
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
W880i not ringing or message alert
Ok, Might seem like a daft question but is it on silent?
I'm guessing you chekced this already but it's easy to miss.
The first thing to check is whether it will make any sound at all - this is a good guide as to whether the speaker is broke or just settings are wrong. Being a Walkman phone you might have some tunes on it so see if they play. Do this through the walkman/media player feature as apposed to the ringtone area.
If they play then you know it's still working and some settings need changing. If not your speaker might be broken.
If the speaker works then you need to check the ringer volume. this can be done from MENU/SETTINGS/SOUNDS&ALERTS/RING VOLUME - this then needs to be set using left and right to go up and down.
After this is set test call the handset to see. If still no luck change the ringtone to another tone - something built into the handset preferably - might be a faulty tune. If still no luck check the the number calling the handset has not got any sound preferences - i.e. no tune when call received. If still no luck it might be broke...
hope this helps some what...
Mar 15, 2008 | Sony Ericsson Walkman® W880i Cellular...
Will not ring
Had the same trouble reset the phone to defaults and do not register handset. Enter the area code and program the ringer volume. Use the PROG (MUTE PROG) key & the CALLERID-VOLUME buttons to make selections in the menu on the screen. to save the setting press the PROG key.
Jan 31, 2007 | GE 28021EE2 Phone
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
