Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower will not turn over.
12f8b
  • 33 Answers
If you can't turn it over by hand ,very bad news,if you can ,check battery,safty switches and starter
Posted on Jul 04, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Start mower with key-cant turn mower off
Your throttle cable need adjusting. Your owner's manual should tell how.
Mar 11, 2012 | Garden
I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Aug 01, 2011 | Garden
Engine runs, blades turn but mower will not move
Look in front of back tired on frame, not deck, there are. 2 rods, 1 on each side, rods look like a L, it's going through a little eye opening, push it backards, mower should move. If rod is pulled through opening and locked in, mower will not move..its a safety. Feather on mower
Sep 01, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Help. I need to drain the oil from my PR600y21RP mower but cannot figure out where/how to drain the oil!!!
You should be able to turn your mower on it's side ( the side opposite the muffler) and look on the motor hub within a couple of inches of the drive shaft and find the oil drain plug on the bottom of the engine ( usually a four sided square end pipe type plug ). once you have found it, turn mower back on it's wheels and start and run it long enough to warm the engine oil (5 min. should work). Shut the mower down...have a flat pan capable of holding the oil volume (a little more than a quart) ready to catch the oil. Turn the mower back on it's side and with an adjustable wrench, loosen and remove the drain plug....with pan under mower quickly turn mower back on it's wheels and allow the oil to drain into the pan. if your mower is equipped with an oil filler tube, remove the filler cap and dip stick. This will allow the oil to drain faster.....when the oil has drained turn the mower back on it's side and replace the drain plug...tighten firmly. put mower back on it's wheels and refill with the proper amount and type of engine oil. fill to the proper mark on the dipstick and DO NOT overfill. Start mower and let run for a few minutes...shut down and check for any oil leaks....and you're done ....hope this helps ;-D
Aug 11, 2010 | Poulan Pro " Pro" Self Propelled Mower
Put mower in reverse, turned it off and mower
There are safety interlocks on zero turn mowers. These prevent starting unless you have: 1. the handles in 'neutral' position 2. the brake on 3. the mower engagement (PTO) switch off 4. yourself in the seat.
Chances are one of these conditions hasn't been met. Since you were reversing when it happened, perhaps you haven't got the handles back to neutral position?
Jul 06, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
53 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
