Question about Honeywell HT-800 Table Fan
Cleaning Honeywell table fan
There is so much dust inside the fan. How can I clean it? Is there a way to open the rim of the fan?
  • Carole Reb
    Carole Reb Feb 14, 2017
    I couldn't figure out how to unscrew anything. The screws that are inside are in there for good. I put the fan in the sink and let the hot water run hard inside. Cleaned it right away. Looks brand new and clean!!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
By the way please check my video on YouTube for your answer. Watch, Subcribe, Share, and Comment!
Thank you
" How to Open a Honeywell Fan to Clean" on YouTube
Posted on Apr 14, 2016
  • Sky Wolf
    Sky Wolf May 06, 2016
    Where is the screws to open a honrywell fan to clean?
    Here is an answer....
    https://m.youtube.com/watch?v=v_vMyy7gkm...
SOURCE: cleaning inside the fan
Unplug the unit from the wall for safety. Remove the two screws in the upper hand grip recess (upper back of the unit). The two screws must be completely removed (not just loose and setting in the holes). Once the two screws are out, the back half of the fan cover can be slid downward (some amount of force is needed to unsnap the two halves from each other but be careful since the parts are all plastic and can possibly snap). Once the back is unsnapped from the front, you can lift the back half away from the front half and the inside parts are now accessible. I have found on my fan that it is the top fan shaft / bushing that is causing the squeaking noise that so many have complained about. I have found that periodically lubricating the top shaft/bushing will make the fan sound like new again - for a while. Every 2 - 3 weeks I need to clean (wipe off old lube) and re-apply fresh lube).
Posted on Jun 07, 2009
SOURCE: how to open seville classic fan for cleaning
All you have to do is where you press the power on /off there is small hole just flipp it using small screw driver and that is where you can find to screws that will allow you to remove the fan.
Posted on Jul 01, 2008
voodoomox
  • 1689 Answers
SOURCE: Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Posted on Jan 04, 2009
  • 7 Answers
SOURCE: Cleaning a HOneywell 14F0 fan
Norm I have this fan & have removed those screws.   Look directly above the switch on the back of the fan, let your eye travel up to the extreme outside edge. Such as where you'd find 12 o'clock on a timepiece.   The screws are very small.  About the size of the head of a finishing nail.
Follow the edge around to 2 o'clock, 4 o'clock, and so on.  Don't blink.
I used a very small philips head screwdriver, the same size as for doing watch or eyeglass repair.  Remember to have a secure place to put the screws, such as a pill bottle, or lid.
And the screws can be difficult to remove, apply a lot of force downward on the screwdriver and turn s-l-o-w-l-y.  Don't strip the head of the screw.
Good luck, Liz/Bizzie Lizzie Atlanta
Posted on Jun 16, 2009
SOURCE: cleaning of the fans
When I called Seville Support I was told that you can NOT open fan to clean and may not get it together if attempted (glad I stopped when I did!).
You need to use air pressure. After using much of a can of compressed air such as you would use on a keyboard and not getting too far, I broke out my seldom used air compressor which kicked out enough dust bunnies as to block out the sun. Hint: be sure to use outdoors. I'm happy to report both units working as good as new.
Don't have an air compressor? Ask your neighbor, he'll need the correct nozzle to 'blow air' (it comes in handy for many tasks).
Posted on May 14, 2010
Cpu temperature error
Turn off PC, Unplug PC from power. Open PC case. Examine all fans including CPU fan and heatsink. clean the fans and heatsink. With case open but everything inside connected properly, Plug pc back in. Power up the PC and check that all fans are running. If not replace fan that is not running. Place PC in a well ventilated area when operating. I use a new small paintbrush for cleaning dust from inside of PC.
Sep 25, 2013 | ASUS Essentio Desktop with Intel Pentium...
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Constant noisey fan. However when it is in sleep mode and you take it from sleep mode the fan is quieter. Any solutions and possible cost to fix. Im using a packard bell desktop 2626 modfel i think. this...
Try opening the chassis and clean the inside of the pc. You can use a blower to remove dusts inside the pc. Usually this is the culprit. Excessive dust will make your cooling system ineffective so the fan will run very fast to cool it down. If your pc is clean, check if there are wires touching the blades of the fan. Also check if there are broken blades in the fan. If everything is fine and still fan is noisy, you have to replace it.
Apr 22, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
My fan wont stop running inside of my PS3 console. What is the best way to remove lint and dust from inside of my console? I would like to clean it myself.
Best thing to use for cleaning dust out of electronics devices is an air duster.
Example found here: http://www.maplin.co.uk/dust-and-dirt-removers-28999
You should be able to pick one up easily from a local computer or electronics store.
When you have it you'll just need to blast the air through some of the open vents to remove any built up dust.
Hope this helps.
Mar 15, 2011 | Sony Playstation 3 (PS3) Console
My dell d620 is very heat using ofter some time fan speed is very slow whate can idow it
It needs cleaning out, there's probably loads of dust/fluff blocking the ventilation slots, CPU fan and air ducting inside.
Dec 02, 2010 | Dell Latitude D620 Notebook
If you don't want to open the case, you can use sprayer, find it in the market, contact cleaner (spray).
Spray the cleaner right into the fan rotor, and to remove the dust, use the paint brush or vacuum cleaner.
Hope it's work!!
Dec 09, 2009 | Maxtor Shared Storage II (S01R320) Hard...
How do i open to clean inside? I can see dust build up and need to clean
Go down to a local shop and ask them if they could blow out the fan for a few bucks with their compressor air supply.
Jul 18, 2009 | Tower Aloha Breeze Fan
Dust inside the fan
you can remove the topcover and can be cleaned using the brush and or vaccum cleaner/ even blower
Jun 01, 2009 | Seville Classics MSC10166 Tower Fan
How to open tower fan to clean it
Use compressed air to blow the dust etc. out of the unit.  You can purchase a  can of compressed air from Home Depot or Lowes, or Google "compressed air in a can."  Just make sure you clean the unit outside to keep the dust etc. out of your home.
Mar 22, 2009 | Dryers
How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Mar 08, 2008 | Olympus Camedia E-10 Digital Camera
Honeywell HT-800 Table Fan Logo
3,532 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
