Question about UPS Battery Backup Systems
Need new password
I just got the net for my brother-in-laws laptop.The password he was using is not working.The only thing it does is goes to password.But he can't remerber his password.
  • 327 Answers
Re: need new password
Do you mean an internet connection password or the systems login? If its the internet, the internet provider will need to assist in resetting the password because the connection is done through them.
Let me know
Posted on Oct 30, 2007
0 characters
3 Points
When the input power is connected looks okay, but when the input power goes off even for 1 second, it goes to "Stand by" mode and the out put will shut down
Get rid of this UPS. I don't like Best Silicon. I have the Manual for it. You need to look into the stacks. Also sound like it set points are out of waco. Did you just replace these batteries? If you did, then you need to reprogram the stacks because they are new. I would call the MFR. Cause you need a password to get into the main menu and to change any stack you need the passwords.
Jan 16, 2014 | APC Silcon UPS System
Dear Sir i will like to ask you if it is possible to change or reset the actually password-protector that have an UPS APC Silcon SL60KF with a master password or reset and for this the ups recover the...
I have had the problem of APC's PowerChute software forgetting my password. No joke. I write these things down when I set them.
Two options:
Call APC support. They are awesome. Smart, well spoken and free. You will need the model number and serial number from your UPS. (800) 555-2725
Remove and reinstall the APC software. During the reinstallation you should be prompted to set a new password.
Vote for this solution if it helps.
Aug 17, 2009 | APC UPS Battery Backup Systems
APC ES 500 when electricity goes out, doesn't keep my computer on
Obvious statement, but it has to be said... ensure that the devices that are to be kept on are on the "battery backup surge protection" side of the device. If the device is at least three years old, the battery may need to be replaced. If this device has the data cable, you can tell the status of the battery by using the software that you should have installed already. Also, since you moved; however unlikely, but open up the battery cover and ensure that the cables are properly seated on the battery terminals. Good luck. -Carlos:
Jun 13, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Can i get a new ip address?
Normal 0 Well, to change you’re outside IP address you need to callyou ISP (Internet Service Provider [Comcast, AT&T]).
As for the key loggers and other spy-ware, you can tryAd-Aware, Spybot, or Malwarebytes. They are freely available on the Internetand might be able to remove commercial spy-ware and should be able to removethe regular (underground) spy-ware as well. Also, get a Firewall (I likeCOMODO) if you don’t have one.
As for you X, she is breaking the law, big time. What she isdoing is paramount to cyber-stalking and malicious hacking. I don’t want to getanyone in trouble, but change all your passwords (after you clean and updateyour computer and change you IP address) and tell here that you will presscharges if she continues to break into your computer.
Good luck,
Eryk V.
Mar 20, 2009 | Compaq UPS Battery Backup Systems
My fan laptop doesn't work
yes I can, you see there can be two things. 1, it can be there isn't enought solicone on your processor. or 2 it could be your fan that went out, fans usually go out like that. My fan just went out too. I recomend going to a computer store and ordering a new fan
Oct 24, 2008 | UPS Battery Backup Systems
Ups problem
The batteries need to be replaced. They probably have more than 3 years.
Replace the batteries and let the new ones charge fully for a day and your UPS will work like new after that.
Oct 14, 2008 | MGE Pulsar Ellipse 800 (89363) UPS System
Laptop doesn't recognize QuickCam® Deluxe for Notebooks (2)
hii john sorry about this .. ok
another solution install the driver clicke here
restarts the computre When will the solution accept my respect and greetings
sincere markknof
Aug 24, 2008 | UPS Battery Backup Systems
Shuts off when power goes out
replace the battery here is a battery from a decent seller there are 5 phillips screws in the bottom, flip it back over and pull th lid off carefully, pull out the battery wires (they are snug) and put in the new battery and put the screws back in.
Jul 10, 2008 | Energizer ER-HM650 UPS System
LInksys Broadband Router
you see doesn's the password you created. it needs a passphrase created by the router.
it looks like this
when you set-up your router on your pc try to save the
"wireless security information"
by copying it and paste it to a notepad or where you could put it.
ok? hope I helped you ^.^
Jan 23, 2008 | UPS Battery Backup Systems
UPS Battery Backup Systems Logo
104 people viewed this question
Top UPS Battery Backup Systems Experts
Jax Planet
Jax Planet
Sudeep Chatterjee
Sudeep Chatterjee
Are you an UPS Battery Backup System Expert? Answer questions, earn points and help others
