Question about Danby 22 in. DDW399 Free-standing Dishwasher
Danby dishwasher leaking from underneath
My dishwasher (less than 1 year old) just started leaking from underneath -- and it leaks quite a bit. It is coming from the right hand side (when facing the dishwasher) near the front -- when I peak underneath I can actually see it dripping slowly.
Although this seems odd, I think it seems to leak more when it is not running and after it runs and I open the door. Or at least by the number of paper towels that keep getting soaked when it's not running.
I double-checked the hoses in the back and they are tight and dry.
If anyone can help, I would really appreciate it!
Thank you! Tina
  • christietina Jun 14, 2009
    Oops! My dishwasher is a Danby DDW497W and not the one stated in the title. Thank you! Tina
    Sergeant:
    Champion:
  • 240 Answers
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Posted on Jun 18, 2009
Why does the crane elephant humidifier leak
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
Feb 15, 2013 | Crane Elephant EE-3186 1 Gallon Humidifier
Danby dishwasher leaking?
The rubber plug has gotten old and does not reseal as it did before.
Aug 22, 2017 | Danby DDW1805W Designer Series...
The bottom drawer is leaking
replace the pressure switch to stop the flow of water that is the cause of overflowing
Jun 04, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Jun 16, 2008 | Danby 22 in. DDW396 Free-standing...
Leaks
try to use lass soap
May 12, 2008 | Danby 22 in. DDW396 Free-standing...
Danby 22 in. DDW399 Free-standing Dishwasher Logo
727 people viewed this question
Top Danby Dishwashers Experts
Jose Pino
Carmen Mikulic
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
