Question about Maytag Neptune MDE5500AY Electric Dryer
Fix Loose Baffles
The instructions for repairing loose baffles are helpful but they don't explain how to lift the lid on my dryer.
  • 1 more comment
  • JMSmith Apr 16, 2008
    I am having problems getting the "shell" of the dryer off to put 2 of the 3 baffles back on that fell off...
  • Anonymous May 11, 2008
    tighten baffle
  • ckhenthorn Jan 03, 2009
    I have two baffles that came off of my dryer. How do I get to the inside to screw them back on?
I had the same problem, one of the baffles had lost a screw and the other side was very loose. Using the instructions here, I took out the four screws inside the door. Two hold the hinges of the door on and two are on the opposite side and hold two small plastic parts on. Once these are removed, pop the front panel off from the top, it hinges down and lifts off. You can now see under the drum and rotate the drum around to tighten the screws that hold on the baffles. Replace the front panel, screw in the four screws and you're done! Thanks to this website and other responses, I was able to fix it myself without an expensive repair call!!
Posted on Jun 01, 2009
The two screws that hold the door door hinges and the two on the opposite side of the door opening hold the front panel in place. Once you remove the door and the other two screws the front panel should swing down to access the screws that hold down the top. But you may be able to reach the baffle screws once the front cover is removed.
Posted on May 10, 2008
  • youths31329 Jan 02, 2011
    Took me all of 10 minutes. Very simple..."Even a caveman could do it".
Took the door off and was able to locate the screw and put it back in place.
Posted on May 19, 2009
The repair comes from the front of the dryer.  Two screws on the very bottom front release the front section.
Posted on Nov 01, 2007
Maytag neptune dryer one of the dividers the screws came loose how can I fix this without calling for service
You are probably referring to the drum baffles. The baffles securing screws can be retightened by raising the top which requires the removal of the front panel. Click on the link below for the detailed steps.
Retightening the Baffle Screws on Maytag Neptune Dryers
Jan 24, 2011 | Dryers
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Need to repair loose Baffle on Maytag Electric Dryer MDE7675AYW
On this model you will see 4 phillips screws in the recessed area when the door is open. 2 on each side. Take the 2 on the right out and then the 2 holding the hinges to the cabinet. Remove the door and then pull the front panel off by pulling toward you. Then you will see 2 screws holding the top down. 1 on each side near the top. Remove these and the top will lift back resting against the wall. From here you can get to the baffles. Good luck and thanks, Rick
Feb 28, 2010 | Dryers
One of the finns inside the dryer is loose, how do I tighten it?
To tighten the drum baffles, all you have to do is UNPLUG the dryer and lift the top panel. The bolts that hold the baffles in place are located on the outside perimeter of the drum. There's usually a minimum of two per baffle. If you cannot figure out how to lift the top panel, post back with your complete model number (located on a nameplate around the door opening or back of the operator console) so that I may be able to assist you further. I hope this helps you.
Oct 28, 2009 | Dryers
Baffle is loose on drum. How do we get access to fix the baffle
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Aug 31, 2009 | Dryers
Baffle loose (Can see hole when moving baffle)
Hi there :)
The baffles are held in by 2 quarter inch screws per baffle. The only way to get to them is by taking off the top lid of the dryer.
Good luck.
Aug 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Maytag drum baffle came loose and catches clostes when drying
I had the same problem and just fixed it. First, open the door and remove four screws, two are holding the door on and the other two are in the same place on the opposite side. Lift the door up and pull it out to remove it. Set it aside. Pull the front panel down. Admire all of the **** that has collected inside the dryer. Next, there are two dark colored metal clips holding the top down on the upper right and left. Remove the hex head screws holding these on. Wiggle them to release them and take them out. Now the lid will lift to reach the screws holding the fins on. Tighten as necessary. Now would be a good time to get the shopvac and clean the lint and junk out of the dryer. Reverse the process to put it back together. Problem solved!
May 24, 2009 | Maytag Dryers
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
720 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
