Question about Kenmore 564-94449400
I transported a Kenmore 564.93445100 compact refrigerator. The refrigerator no longer gets cold. It's just slightly cool. I'm thinking that it needs refrigerant but can't tell where to recharge it at. The compressor stays on constantly.
catriver
  • 878 Answers
SOURCE: Refrigerator making a whinning noise.
sutty, you have a 2 speed DC evaporator motor in this model. There should be at least 60 seconds between any fan speed changes. On the back side of the refrigerator you have a main board. Unplug J2 connector on the board. Check for 13VDC between pins j2-3 and j2-8, then check for 8 to 13VDC between j2-3 and j2-4. If the voltage is correct I would suspect the evaporator motor. If the voltage is incorrect, then the problem is in the main board. Pins read from left to right 1 through 8. Catriver.
Posted on Jun 30, 2007
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
bobotfel
  • 236 Answers
SOURCE: Recharge Refrigerant 134A into Fridge
Some technicians tried that, they just replace the compressor oil. But I did try that yet.
Posted on Jan 02, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore refrigerator not cooling
hi thanks for the question if both fans are working no ice build up & no dirt on condencer by the compressor sorry but you need a new compressor thanks the appliance doc
Posted on Sep 22, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
Kenmore bottom freezer refrigerator 795.79004.905. Refrigerator not cooling.
Not an easy refrigerator to diagnose but here is a link to a Service Manual=> HERE Go to pages 21 through 23 and try to do the diagnostics. The problem could be several things including a defrost failure. Otherwise you will need to get a technician out to help you resolve this. I will try to help you should you need ask.
Appliance 911
Oct 06, 2015 | Kenmore Refrigerators
Kemore compact refrigerator
It sounds like the temperature control is inoperative. They aren't too hard to replace, and $150 seems high for a control, but If replacing it is not something you or a friend could do, then a new refrigerator seems like the best choice for you.
Nothing lasts forever, and if you have already got 15 years of service out of it, then it would be a bad gamble to put that much money in a repair. I'd buy a new one and sell your old one on Craigslist to someone willing to fix it. You may find that you can go a lot longer than two weeks between defrosts during drier parts of the year, and the 'fridge isn't going to care if you go a lot longer than you think is necessary between defrost cycles.
Apr 18, 2014 | Kenmore 91495 Compact Refrigerator
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 25, 2011 | Haier HRT02WNCBB (17 cu ft) Compact...
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 26, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer willnot longer get cold only cool air
Do you hear the compressor humming? If the compressor does not run then your freezer will not get cold.
Aug 30, 2009 | Kenmore 54263 Stainless Steel Side by Side...
Refrigerator and freezer are not cool
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator not cooling very well, upper freezer appears tobe ok
HI,
thanks,
Mar 29, 2009 | Kenmore Refrigerators
Kenmore fidge not getting cold
transporting fridge items on the side mixes up the oil and the gas together, inside the compressor bottle at the back, this should never be mixed, when you move fridge appliances you should always stand appliance where it is going to be for 24 hours before switching back on to allow the gas and oil to settle and separate back apart again. many engineers may tell you this does not matter and you can lay items down etc, this is absolute bull and must not be done as for allowing it to stand 24 hours, the opinion is mixed, but common sense tell you, if you move something, let it settle afterwards, and the longer you give it to do so the better OBVIOUSLY sorry there is no diy repair
Oct 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 564-94449400 Logo
356 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
