Frigidaire Front Load, 5 Cycle Heavy Duty A full load of laundry, but not stuffed... The washer shut off mid-cycle and won't start up again in any position of the dial. When the knob is pulled out in any position to engage the machine a light comes on with "door locked"... and indeed the door is locked... I've never had any problems with this machine before....
  • 1 more comment
  • stevegilman Jun 14, 2009
    Frigidaire Front Load, 5 Cycle Heavy Duty A full load of laundry, but not stuffed... The washer shut off mid-cycle and won't start up again in any position of the dial and a light comes on with "door locked"... I've never had any problems with this machine before....
    ...was able to get it to start at the top of the dial... all it did to mid-dial where the trouble happened (machine stopped/got stuck) was cycle gently back and forth. Moved it manually a little further and the 2nd rinse came on -- followed by the high speed spin (SO IT WASN'T THE 1ST SOLUTION) and it looks not to be the 2nd solution either...
  • stevegilman Jun 16, 2009
    Yes, the other "solutions" were way too simplistic...
    Brigadier General:
  • 8,619 Answers
Hi
Please turn off your washer and unplug it from the power socket for 30minutes. After this check if the error is still there. If the error comes again then to remove the error you’ll need to enter the diagnostic mode—
The diagnostic test is performed by using the Program Knob. To START THE TEST:
On non-digital display models, turn the Program Knob to start position, Drain/Spin.
On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360 degree, turn the Program Knob to start position, Drain/Spin.
Press Pause Cancel to turn off LEDs.
Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.
7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Exiting Diagnostic Mode
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED�s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
To clear latest stored error code:
  1. Place the control into Diagnostic test Mode.
  2. Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  3. Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  4. Exit Diagnostic Mode to return the washer to normal operation.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 14, 2009
  • 15,935 Answers
Your timer/controller board has failed.
To unlock manually - remove the bottom kickplate with 2 torx bits.
Reach up toward the locking mechanism - and locate a teardropped shaped tab.
Pull straight down.
If you use the "Continue With This Expert" option and reply with your exact make/model # I can assist you further with replacement parts & troubleshooting.
Thanks for using FixYa!!!
  • 3,230 Answers
Drive motor
Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Good Luck!!
Thanks
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
How do i clean the washer?
you need to put affresh tablets into the tub and set it to clean cycle if it has it or heavy duty with hot water. you can get affresh tablets at just about any store in the laundry detergent isle.
Jun 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
