Question about Dell Inspiron 1420 Laptop
Black Screen I have a Dell Inspiron 1420 Laptop and when I turn it on it starts up but the screen stays black. The only thing you can see is the white mouse cursor.
  • colin butcher May 11, 2010
    Is there an operating system installed? if so it could be hard-drive failure or screen failure
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
Its either your inverter or ccfl backlight tube that is out
here is a tip, if you ever buy a new laptop, try to get one with led backlight technology, they last a lot longer and are more durable
Posted on Jun 14, 2009
  • 61 Answers
Sounds like your graphics adapter isn't working correctly or there's a problem with something in Windows (I'm assuming you're running Windows XP). If so, restart your computer and hit F8 until you get a menu. Select Safe Mode and see if it boots up correctly. If it does, note any error messages you may receive and then shut it down. After shutting it down, let it start up on it's own and see if you get your picture back.
Laptop Monitor goes black close and device disconnect will sound, then open device connect will sound then runs good all day
hi how are you could you restart you laptop when the dell sign in the screen press on (F8) then go to safe mode to making system restore
to making system restore from start icon after that write in search box (system restore) to rest the system to previous date before
i hope that will help
Feb 22, 2014 | Dell Inspiron 1420 Laptop
My Dell Inspiron 1420 screen goes black
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 02, 2012 | Dell Inspiron 1420 Notebook
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
Dell Inspiron 1420 blackened screen when turning on problem
Go back into Safe Mode, and try to run a system restore to a date where this issue did not exist.
Jan 10, 2010 | Dell Inspiron 1420 Notebook
My Dell Inspiron 140 have no imags. Power leds is on but no pic on the screen. Please Help.. Thank You,
try plugging it into an external monitor you may need the latest drivers for your video card for this to work if you get no video still then it could be your video card another thing to check is to see if you shine a light at an angle down the laptop screen if you see a faint picture it could be your ccfl's need replaced if it is still black but works on the external monitor then it could be the inverter hope this helps
Oct 07, 2009 | Dell Inspiron 1420 Laptop
Screen is black laptop on but have to screen
I believe the inverter on the screen is broken. If you are able to see a dim image on the screen with the computer on, then you need to have the inverter replaced.
Oct 01, 2009 | Dell Inspiron 1420 Notebook
I upgraded vista on my dell inspiron 1420 and now my screen is just black. Help!
how did you install the new operating system.was cd absoulouty clean no scrathes.did you formatt.did u create a new partiton did u remove old OS..Try reinstalling..is your systen compatable with vista.if not it wont work..there are things you can do.
Sep 20, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 1420 startup error
You need to cheat a little. First try to boot into safe mode by pressing the f8 key as soon as you hit the power (and keeping your fingers crossed on the other hand that it notices your doing this). Before you get too depressed just try booting into safe mode and then reboot normally. That may be all it take to fix it. Try this a few times before getting into the more serious fixes.
If you can get into safe mode you can simply copy your files off to a usb data drive. Those will still work. You may be able to use the wired network card if you select safe mode with network access. But don't count on that. The cd/dvd will not work so you can't burn it to disk. A flash drive will work on the usb while a external hard drive that connect via usb usually won't as it needs drivers.
The other way is to boot using a bootable cd. If you can get a vista install cd you can install over the top of your existing windows and retain your settings. If you don't know where everything is then you need to be a bit creative and use something like the demo Ubuntu cd that boots into a windows like operating system that will allow you to copy stuff over the network to the usb drive or the network.
If you have a friend with the right laptop or desktop you can take the drive out and set it up as a second drive. When they boot normally they then can see your drive and just copy burn or move your stuff. This is what I do in the shop when the existing system is too messed up to work with. There may be the odd thing you won't get access to but you should get most of it.
Jul 09, 2009 | Dell Inspiron 1420 Laptop
Problem in os
Try starting explorer by going to file\new task (run..) and typing explorer.
If it doesnt work, just type msconfig on the same box and go to startup tab, leaving everything unmarked, just reboot your pc and problem should be solved
Jun 21, 2009 | Dell Inspiron 1420 Laptop
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1420 Laptop Logo
340 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
