Question about Sony CDX-M610 CD Player
Sony cd car radio
After about ten minutes of playing a cd on my sony cd radio the unit turns itself off.within a few seconds it turns back on,but the unit needs resetting ie.the preset radio setting have been lost.the unit has only ever turned off when i am listening to a cd and not the radio.
    Problem Solver:
  • 8 Answers
If you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Posted on Dec 14, 2007
I have a 1993 Mercedes 300 SE and after I got the radio unlock code from mercedes the radio worked all day just fine. I started the car the next day and the radio had a E 3 message on the display when I...
I dont remember if that year had a theft lock system or not, but I am looking into it. disconnect the negative battery cable for ten minutes and that should get you back to where you can enter the unlock code again and use the radio.
Nov 01, 2013 | 2004 Mercedes-Benz Mercedes Benz S Class
Hello. I have a Philips FW-R88 CD player that I think I bought about ten years ago. A while back, it started turning itself off and then back on randomly (usually after playing somewhere between thirty...
Clearly some kind of power supply issue as it is on both devices. It might be faulty capacitors or something wrong with the voltage control circuit.
Nov 27, 2017 | Philips FWR88 CD Shelf System
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
When there is a CD playing, there is no problem. But when I take the CD out, the radio does not function properly. It switches back to CD and then changes the radio station every 1-2 minutes!I can not turn...
Unfortunately, this sounds like an internal problem with the radio. Internal as in within the radio itself, not a wiring problem. Not really much you can do about it. Sorry. Probably need a new radio. Good luck.
Dec 04, 2009 | 2001 Hyundai XG300
The player will not eject the cd but it will not play it either.
I know it sound crazy, but turn the system on, press eject while using a PLASTIC knife to lift the CD in the player. If the system is stock also try disconnecting the radio fuse for about 10 minutes or so with the car off. Reconnect it to see if the radio resets. You'll know the power completely went out because you'll have to reset your stations. By Resetting, hopefully the issue will solve itself. In a few of the system issues I've seen, when the motor won't open the faceplate, or the CD player won't give the CD back. I usually remove the faceplate or disconnect the negative side of the battery for about ten minutes. Try this if the fuse removal doesn't work. Good look. Let me know how it goes. there are other things to try.
Jul 27, 2009 | 2004 Honda Pilot
My Sony Hi Fi System also turns itself off-when I try to play cDs
Check if you can see for the belts on the cd deck and change them
Jul 04, 2009 | Audio Players & Recorders
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Dell Latitude D600
Check that the cpu fan is working. In easynote usually you uncrew a panel at the back of the laptop. If it is not that may be a common system problem, in that case reinstall your system.
Mar 13, 2008 | Dell Latitude D600 Notebook
Cd-changer Blaupunkt IDC-A09
The solution is to disconnect the head unit and the cd changer from each other and from the car itself, leave it for ten minutes. reconnect and turn the ignition on but not the car itself, enter radio code if has one and all should work.
Sep 24, 2006 | Blaupunkt IDC-A09 5-Disc CD Changer
Sony CDX-M610 CD Player Logo
286 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
